Hinerman
11:43 AM
NE OK
Working on a 170 stihl I know you guys were putting an adjustable carb on them but having trouble they stihl. Where are you sourcing your carbs from?
amazon
67L36Driver
11:43 AM
Workshop
11:43 AM
Nixa, Mo.
Helped my son put coolant in the Van this evening. The Van holds 7.5 gallons coolant altogether. This vacuum thing he has put every bit of the coolant into the engine before we even started it. Then we fired it up and let it thoroughly come up to operating temp and let it run for a good 30 minutes. Smoothest, quietest engine I've ever had.
moparnut88
12:43 PM
US
That’s awesome! You’ll have you a good rig there! And yes those vacuum fill systems r a must for a lot of the newer chevy and Ford engines. Can’t do it any other way.
MACHINE
12:43 PM
Broken Bow, Oklahoma
Amazon, that funky cover on factory carb will bolt on the chicom walbro style carb , dill adjustment holes in side of saw so you can adjust.
Here's a tip , take coil off and file the hole on it to add a little timing. Or file the key , really wakes them up
I've done 5 or 6 for people, gut muffler as much as you can as well .
I have 12 in bar on mine and I use it 95% of the time , it stays in a case in my Ranger
Also drill out tank vent and run hose to carb area and use sthil tank vent , that helps as well.
Sent from my SM-G975U1 using Tapatalk
JimBear
11:43 AM
IA
I ordered another barrel of b/c oil awhile back & told Dale to just drop it at the shed whenever no hurry. He called yesterday & said they don’t sell them anymore because there was a lack of interest in them so he sold me a pallet of cases for the same price. I guess I won’t complain, it was delivered. I was hoping to catch the fall oil/grease sale but they weren’t having one this year.
Semotony
11:43 AM
You must do good work!
