Sawdust Man
Manufacturer of Sawdust
10:05 AM
MO USA
Just get them dry and out of the weather, and they’ll last longer than you’ll have need of them.
Stacked in contact with each other where moisture can be between them is the worst thing for them.
This is the truth....
Good morning guys.
Thankfully we ended up about an inch of rain yesterday.
Hedgerow
10:05 AM
Got back from MI last night and poured 1.9" of liquid from the rain gauge.
Now maybe the chisel plow can get to it's maximum depth.. We got a lot of tight packed acres to run through this fall..
Sawdust Man
10:05 AM
MO USA
Anybody know anything about busted gears?
It's the planetary guts for the rear hub on an '07 Allmand TLB535 backhoe, no longer in production, and the only source for parts is a place in ct that's totally incompetent.
67L36Driver
10:05 AM
Dang, it turned out to be a bad day!View attachment 347471
Come down to “Who made the gearbox?”.
Like most machine builders they source their subassemblies from manufacturers.
Hedgerow
10:05 AM
If you can get all the specs, Bates bearing or bearing headquarters might be able to help..
No guarantees...
Sawdust Man
10:05 AM
MO USA
I kinda figured the rear axle assembly was made by someone other than Allmand, but I haven't been able to find any info on that so far, I'll have to keep looking.
Thanks.
plcnut
Jesus is LORD
10:05 AM
Mansfield, Missouri
Were you able to determine the cause of failure?
Or does that appear to be the only broken piece?
That would be quite a brazing job, but I bet it could be done. I don't know how it would hold up though.
