Homemade chainsaw brake band.
psuiewalsh
Basement Bodging
12:14 AM
Nottingham,pa
With a flat back couldn't you mill out a pocket of the shape with the protrusions and pour a castable rubber?
Mattyo
Youtube speciawist
12:14 AM
Farmington, CT
I like the 3d printed idea ... if you have something even slightly flexi it would probably work fine.
J & L Creations
Machine Design
11:14 PM
Texas
Ok, a 3d printed one would be the way to go, I've never messed with rubberized filament before, so there would be a learning curve.
J & L Creations
Machine Design
11:14 PM
Texas
Yes you could, you might also be able to use spring wire or the right size braising rod to do the same job as the rubber bumps.
Mattyo
Youtube speciawist
12:14 AM
Farmington, CT
The brake band is perfect...which is why I was derailing the thread lol!
J & L Creations
Machine Design
11:14 PM
Texas
I wander if Jeff's band making would work on some ones 2100? Seems like most of them need one!
I think one could make a band for any chainsaw that needs it, I'm sure most here could make one, just need a little skill.
Adirondackstihl
12:14 AM
Upstate NY
Great job, but titanium isn't the ideal material for a brake band IMO.
J & L Creations
Machine Design
11:14 PM
Texas
The only way I could see the material I used could have detrimental effects would be if the brake band was constantly rubbing on the clutch drum, I made sure it did not rub. That would be the case with any saw that has a brake band system though. So using titanium, I thought it would last much longer and handle the heat better, but one can use any material they desire or have at their disposal, not saying everyone should use titanium. Just showing and proving that a person can build/repair something if they put their mind to it, or develop/have a skill set to do so, that is the point of this exercise. We live and have become a wasteful throw away society, spending money needlessly. When if we just use our head a little we would be much better off. Thanks for your input.
