HOMELITE Homelite Thread
heimannm
7:43 PM
Dike, Iowa
I need help from someone with a good understanding of late model Homelite saws...in this case dressed in John Deere green...
J3816
What model Homelite is this? I'm pretty sure Fossil already schooled me once but I have not been able to located that information again.
Are there other Homelite models that were also dressed up in green? Does anyone have one in really nice condition they would be interested in letting go? This could include an Efco version. Asking for a customer...
Mark
They call me Mr. Kibbs
8:43 PM
Wandering the VA woods
J3816
If it's a 45 cc version it may be a Timberman. Back about 2003 I was a little thin on funds and wanted/needed a 20" chainsaw. Bought a Timberman not knowing any better, and it looks a lot like your JD. Actually not a bad saw, starts and cuts after sitting for years at a time, but should have never been paired with a 20" bar.
Partner
2:43 AM
Poland
People buy with their eyes, so the guide bar is often too large in cheaper saws
fossil
8:43 PM
Ontario, Canada
J3816
Mark
Doing a bit of digging, this one is a little more complicated than the last one I did some digging and I'm making some assumptions.
The 45 cc Homelite Timberman looks to share the same plastics as the John Deere J3816.
Looking at the IPL (attached) for the Timberman, it shows the 38cc version using the same cylinder as the 45cc version. The 38cc verstion is UT10927 and the 45cc versions are UT10942 and UT10946.
Unfortunately I can't find any specs on the John Deere or Homelite bore and stroke.
That's about as close as I can get.
Just a side note digging inro my diminishing memory. Poulan 34XX, 38XX and the 40cc saws all used the same 40cc cylinder. Maybe a similar case with your John Deere.
Tim
lehman live edge slab
Live Action
7:43 PM
Mn
Tim
My uncle had one of them because he was a homelite dealer back in the 80’s needless to say he could tell it wasn’t the homelite of old. John Deere had pretty much every homelite in green yellow over the time they owned them. I should have bought the homelite 250/300 in Deere trim up here when the dealer went out of business along with the super xl in Deere colors.
Live Action
7:43 PM
Mn
J3816
Mark
Here’s some of them, I really didn’t realize they sold a green machine “by John Deere” version of a few also and I don’t own any of them just showing you a few to search for. But I will ask locally some of the guys i know
LAWN BOY
Pothole
5:43 PM
Merrill, WI
I have a green machines saw, but I think mine is a Tanaka rebrand.
The 350cs is definitely a bucket list saw for me, Leon's is in really nice shape there. I forgot to bid on one on eBay that went dirt cheap not too long ago.
RonaldT
7:43 PM
Northwood Iowa
I asked a John Deere saw guru. The 3816 is a homelite built saw. I stand corrected! He said it's the last John Deere saw made. The prior green ones were made by Efco. This doesn't answer the original question as to what homelite model it is but I enjoy saw trivia!
LAWN BOY
Pothole
5:43 PM
Merrill, WI
There was also i believe the model 61, an earlier John Deere saw made by Remington or whoever made the Remingtons and Montgomerywards at the time.
heimannm
7:43 PM
Dike, Iowa
I ordered parts to repair the J3816 (brake handle, rear trigger handle) but unfortunately the rear handle was also broken when it arrived. This inspired me to have a look at some plastic Homelites in the attic and what do you know, I had a suitable donor saw on hand so that project is now complete. Thanks again to Tim for the inspiration.
On a completely different note, this one came in today. I already have a pretty good looking 26LCS in the display so if anyone is interested in a hard case project I have this one available.
Mark
heimannm
7:43 PM
Dike, Iowa
The 26LCS shown above has found a new home in Oregon...
Today I have an SEZ on the bench, 160 PSI compression and a snappy blue spark. I went through the carburetor, diaphragms and gaskets are nice and supple, HS check valve works, metering needle holds pressure. Replaced the fuel line and fuel filter. Saw will start, pop a few times, then quit. Might restart again with the choke, might not.
I have cleaned the points, set the gap at 0.015", replaced the plug wire, flywheel key is in place and the flywheel is locked down tight. I have tried two different spark plugs with no change in behavior.
Any additional ideas would be appreciated.
Mark
