Grease Monkey Garage
mainer_in_ak
7:29 PM
Interior Alaska
I have used is in my old s10, did a lot of mpg testing with it. It worked the best of all the things I tried, it would pick up 1-3 mpg on average, a friend gave me a half case when he got a diesel
What year s10? I wonder if a little lubricity and detergent in the fuel helped those little poppet valves open and close more efficiently. They're subjected to heat and carbon build-up.
In my old vortec 350/305/4.3 vehicle manual, you were supposed to run a fuel cleaner to keep these little poppet buggers propper.
FergusonTO35
11:29 PM
Boonesborough, KY
Anybody know the good or bad about a 2009 F-150 4x4? My in laws are going to look at one that's supposed to only have 94k on it. From what I understand they are good as long as you get the 4.6 2v engine. I don't know if Ford was still using the E40D transmission in 2009, I remember those being really good in the 90's trucks.
hacskaroly
2100 Fanclub Member
8:29 PM
Northern Idaho, Ehh
I have an older 98 F250 4x4, odometer shows 405k, I bought it at 400k miles. It is on it's second engine, 5.4 Triton v8, changed out about 6 years ago (according to the invoices in the glove box), so I don't know exactly how many actual miles are on the current engine. It currently has a small head gasket leak, but no oil/fuel/bubbles showing up in the coolant, I am guessing when the engine was replaced, the heads and block weren't resurfaced. Everything else seems to be running good, still has get-up-and-go and transmission is shifting as it should without issues. I just had a plastic windshield wiper bushing go, it had been running for a while without grease and just wore the plastic down. $12 for four new bushings and it is back in business.
I have heard bad things about the 5.4 engines (mostly from the internet), but the mechanic that has looked at mine says they are good engines and the one I have is running pretty solidly minus the small leak. I look forward to driving my truck everyday, I enjoy it. It still has some minor issues to resolve like fixing the cruise control, lights to the 4-wheel drive knob and 4-wheel low (4-high works fine).
They call me Mr. Kibbs
11:29 PM
Wandering the VA woods
Might do some research on the spark plugs. I have an '06 F350 with the 5.4, and although I change them often enough to not be a problem, they were known to seize up in the head and break when trying to remove them. The '14 E250 we had at work ejected plugs like a pez dispenser. We sent that one down the road after the 3rd one. It had the 5.4 also, but I seem to recall that the 4.6 had its share of plug issues also, best of luck!.
As long as I'm here, does anyone know what Ford's thought process was with having 16 plugs in the 6.2 gas? I bought a used '19 F250 about 6 months ago and just have not been in the right circles to ask anyone yet
hacskaroly
2100 Fanclub Member
8:29 PM
Northern Idaho, Ehh
I have not heard of that, is that two plugs per cylinder (8)?
Edit: I have heard of this in aviation engines, appears that these in vehicle engines are to ensure more complete and even burn?
AI states: Engines use two spark plugs per cylinder primarily for more complete and efficient combustion, leading to better power, fuel economy, and lower emissions, while also providing critical safety redundancy, especially in aircraft, where a backup plug ensures the engine keeps running if one fails. This dual ignition creates two flame fronts, ensuring rapid and even ignition across the entire fuel-air mixture, preventing hotspots and misfires, particularly in complex cylinder designs or at high RPMs.
alfack
9:29 PM
Idaho
My '06 F150 is running strong. It has the 5.4 3 valve engine. The first plug change, 5 broke off in the head. Had to get a special tool to extract them. I rebuilt the top half of the motor with upgraded oem parts, as preventative maintenance for cam phaser issues. Solid truck, now.
FergusonTO35
11:29 PM
Boonesborough, KY
When I was a tech, I remember the 90's and 2000's 4.6 was a really good engine and we saw few problems with them. Now the truck surrounding it wasn't that great, but at least the drive line was good.
FergusonTO35
11:29 PM
Boonesborough, KY
Ford and Nissan had a hard on for two plugs per cylinder, mostly in the four bangers. I didn't know that some of the V8's had it too. A parts bill for 16 iridium plugs, man that's painful to think about!
11:29 PM
At l
I was thinking the same thing and just think if you need to replace the coil packs too!! 😭
No kidding! At least the recommended interval is 100k miles. Of course, with my driving requirements that's about 4-5 years.....Meh, as long as they don't break and spit out like past Ferds I'll look at it like is was a '65 283 that needed 8 new plugs about every 20k miles. Course that plug change took about 20 minutes!
FergusonTO35
11:29 PM
Boonesborough, KY
So, dealing with 1950's electrical tech on my tractor, which is 12v -ground. Looks like my key switch is not sending 12v to the ST terminal on my solenoid when the key is in start position. It looks to me like somebody crossed the wires on the switch before I got the tractor, because I see the 12v from the ammeter is connected to IGN (orange wire on the left). Then black to the coil is wired to BAT. The ACC and start terminals seem to be wired correctly.
Another thing I find is I have about .5v drop between the switch and the ammeter, compared to battery voltage. Is that correct? Do ammeters cause that much of a voltage drop? Also, I think I'm going to put a 30 amp fuse between the battery and ammeter for safety. Is that enough? Or should I go higher or lower?
hacskaroly
2100 Fanclub Member
8:29 PM
Northern Idaho, Ehh
Fix or repair dailey.
I hear that, the other day while raining, one of my windshield wiper armature bushings failed causing a loud noise as the arm fell off and the wipers stopped working. A new set of bushings and it was back in business. Topped off fluids today, watching the coolant level due to head gasket leak. Other stuff I keep finding as I go. Better Fix or Repair Daily than Found on Road Dead or F*ed Over Rebuilt Dodge... 🤣
FergusonTO35
11:29 PM
Boonesborough, KY
A cheap ass Fix Or Repair Daily 1998 Ranger is the best vehicle I ever owned. Slow, no air conditioning, noisy. But simple as dirt, cheap parts, good mpg. I took it places off road that would be challenging even for 4wd, I lost count of how many deer we hauled out of the woods with it. Sometimes I regret letting it go when I bought Dad's 2012 Dodge 1500 Outdoorsman. Which is a very nice truck and a lot more capable, but also has a lot more stuff that can go wrong.
hacskaroly
2100 Fanclub Member
8:29 PM
Northern Idaho, Ehh
Here is my daily fix for my 1998 F250, coolant temp gauge has been flaky and today on my way home from work, didn't lift off of the bottom of the gauge, heater blew cold air the whole way home. The coolant reservoir was was full and overflowing a little (due to the thermostat not opening up). Tested the gauge (shorting out the pins on the connector) and the gauge pegged hot. Went to O'Riley's and got one of their AM temp sensors and it didn't work (it fit, but didn't register anything), I wasn't surprised, the reviews weren't that great, but everything else was closed. I thought I would meter out the sensors and see what they say here is what I found:
* O'Riley's states that the manufacture range should be between 27,000 and 31,000 ohms (not sure if that is just the ambient temp range or the hot/cold range)
* The original OEM sensor metered out at 6,000 (cold 70F water) and dropped to around 500 ohms in 212F water.
* The AM sensor metered out at 28,000 (cold) and dropped to about 24,000 ohms in 212F water.
I ended up cleaning the corrosion off of the OEM sensor with a brass brush and scotch bright and reinstalled it and it ended up working. I will use it for now until I can order an OEM replacement.
My question surrounds the resistance readings from the sensors, should it be a specific ohm range these work in or is it more of a percentage of resistance? I am using a Fluke digital multi-meter that is auto sensing.
