- 9:19 PM
- Dec 4, 2015
- In a meeting
Is that going in the lawn mower in the background or the atv?
Led lights.....
Details, details.The LS ignition coils aren't exactly world renowned as a thing of beauty, so in attempt to make them slightly more appealing to the eye, I hit the shields on them with some gray metallic.
Looks great Kev. Refresh my memory, what power plant have you got between the fenders?Got the drivers front brake line inView attachment 424399View attachment 424400View attachment 424401
Going to “tweak everything” after all 3 lines are screwed down.
1 down, 2 to go
A very smoothe idling-yet agressive street cam’d “74 302 that’s been redone, 0.030 over cylindersLooks great Kev. Refresh my memory, what power plant have you got between the fenders?
According to these guys, they are somewhat similar? https://www.enginefacts.com/ford460/Did 429's, never a 460.
I have no idea on the heads. I'm very familiar with GM and Chrysler. Never worked on any old Fords other than a straight six.
I'm looking forward to working on this engine as I like to gain efficiency. Sounds like the exhaust is the first place to start?
This is the most in depth information on porting a 460 head you will ever find. Not free, but 100% worth the cost.Anyone here ever built a Ford 460?
I just bought one and going to pick up next week. Thinking after I check it over, I will probably start looking at the exhaust as apparently post 1970's head flow poorly on the exhaust side.
The 429 is the same family, just pre emission. Higher compression ratio, better flowing heads and cam timing.
Rebuild still got new pistons, cam, timing set and the heads get hardened seats installed.
Fuel mileage didn't seem to vary much whether you had a 300 six, a 460 or anything in between, unless the gearing was stupid from the factory. That did happen every now and then. Power on the other hand varied greatly.
no finer mechanism exists to turn gasoline into noise and heat than the 460 hahaI know my 300 gets twice the milage as what my 460 got. But a 460, C6, 4:11 is not exactly the best economy set up!!
I had a F-150 300 with 3 speed + overdrive and 2.73 gears AND a Bronco 351 HO 3 speed auto with 3.50 gears. WTF! Neither one got mpg's. The 300 would lose speed in od at 65 mph. It would drop the rpm to 1350 at 65 mph.I know my 300 gets twice the milage as what my 460 got. But a 460, C6, 4:11 is not exactly the best economy set up!!
