- 9:57 PM
- Dec 3, 2015
- Banner Springs Tennessee
Don't do it, it's a trap.The thought crossed my mind, JJ.
Looks Kawi not Yami ????took apart the front of my brother's Yamaha to asses the damage.
Yep, a few pins, some stitches, and a bunch of cuts and bruises from the scrub oak that caught him has really taken the wind outta his sails.It looks like your brother was having a great time until he didn't.
Yep, I got confused. Mine's a Yamaha, his is an 04 Kawaskai KX250F.Looks Kawi not Yami ????
pinch the bracket and weld it back together.First off, I'm dumb as a box of rocks with transplants of efi engines. All carbed in my day.Got my tall/narrow mounts.
The tabs won't spread enough to fit the short/wide frame brackets.
If I get the tall/narrow frame brackets I'll see no gain as they are the same overall height when assembled..
I'm thinking I could cut a slot where I'm indicating
View attachment 426770pinch the bracket and weld it back together.
But, then I'm stuck using the tall mounts for sure... unless I shim the wide mounts.
As of now, I'm leaning towards ordering a knock off Holley 302-2 oil pan at $140 vs $500 for the Holley. That with the short/wide mounts and maybe a small shim should get me clearance and still give my bellhousing room and not tip the engine back.
It seems the 66-67 GM A bodies are not as easy of a swap as the 69-72 frames.
Did they ever put that engine in a lower profile engine bay that you could rob parts from? Maybe a Z28?
You probably already know this but the 98-02 F body LS1 oil pan is what the Holley pan is based off. I had to use one for my swap.Are you talking factory parts?
If so, the pan I have is the lowest profile factory pan made for the LS.
I can make it work but I also have to factor in room for the trans and the angle of the power train in the chassis. If I get the engine too high to clear the steering and frame the trans will either hit the tunnel or I will have to tip the entire thing way back which creates driveline angle problems plus will point my headers at the ground.
The Holley pan is very shallow at the front plus has no cast in bosses like the GM pan.
You’ll also want the oil pick up tube and you’ll likely have to modify the splash plate for clearance
I don’t have any real good pics of the oil pan I used. These are about all I could findThis boss for the trans cooler line bracket is definitely in the way..
View attachment 426780View attachment 426781
I read where this pan was used on a 67.
They must have better skillz than me to make it fit.
The pan @Canadian farm boy is talking about is much shallower in the front as well.
Speedway has a steel pan and radiator kit I'm eyeballing as I need a radiator too...
Man, shoving a 440 into a '34 Dodge was easier to figure out.Are you talking factory parts?
That a whole lot of badass right there! Did Ford produce those 4x4 from the factory or was that a 3rd party conversion?
Not sure. They are @The Extractor 'sThat a whole lot of badass right there! Did Ford produce those 4x4 from the factory or was that a 3rd party conversion?
