Grease Monkey Garage
Steve
Excellence!
1:34 PM
redline4
I'm huge in Japan
1:34 PM
Rosholt Wisconsin
Do you have the ability to cut valve seats Ed? I have a small neway cutter set for small engines and it's amazing! Just a little pricey.
We have a valve grinder at work.
80% of the pieces and parts are missing.
I was going to hit them with a bit of lapping compound and see how they look. If they aren't what I'm wanting, I'll have to have a machine shop go at them.
redline4
I'm huge in Japan
1:34 PM
Rosholt Wisconsin
My stepdad had my stepbrother and myself lap valves with a crank tool that looked like an egg beater with rubber arrow tip on it. That seem to take forever.
I only have the version you roll between your hands with a different size cup on each end. I've had to replace valves in used heads many times and have not had any issues with getting them to seal with a bit of manual labor. Of course the end result of a 5+angle valve job that the car magazines tell you that are required to make more than 100hp isn't achievable.
jacob j.
Only the weird
11:34 AM
Coastal Oregon
Slacker.
1:34 PM
I chuck the valve stem in a drill.....use lapping compound on the valve seat....and spin.
