Grease Monkey Garage
nbbt
4:54 PM
5543X, 5644X
Dad had a 1964 with a 250 in a 3/4 ton, 4 speed with granny gears. In 1st at a idle it was the perfect speed for watching the wildlife on dirt roads. wink, wink.
Not a speed demon but went down the road just fine with a cab over camper, and towing a boat. 67-70 was really pushing it..
Yukon Stihl
2:54 PM
Great White North
Plus temperatures here for the last few days so i took advantage of it and plucked the 5.9 out of the Ford it's been sitting in for the last 15+ years.Happiness is having a skid steer with the warm temps i was able to leave the garage door open.After seeing some of the conversion work done i am calling it a rescue97 5.9.e.jpg 97 5.9.jpgb.jpg 97 5.9.e.jpg 97 5.9.jpgb.jpg 97 5.9.f.jpg mission.
FergusonTO35
5:54 PM
Boonesborough, KY
Is that a one ton? I didn't know they ever put Cummins in anything less than a medium duty.
Stevetheboatguy
4:54 PM
Nw IL
Got some work done on the 300 this weekend. Using King rods and mains in this build. Upgraded to hypereutectic pistons. Standard cast rings.
View attachment 363220 View attachment 363221 View attachment 363222 View attachment 363223 View attachment 363224
So just out of curiosity. Any idea on why there isn't a main bearing with a thrust face? Or does ford do it differently to control fore and aft movement?
What did you find out on the cam bearings?
Edit: disregard the thrust bearing question. When I went back and looked there was a picture I missed. I see it now 3rd from rear.
Steven
Steve
Excellence!
4:54 PM
Steven
Yup, main #5 has the thrust bearing.
I ordered a set of King branded cam bearings. Opened the box and they were just reboxed dura-bond. Nothing like paying an extra 10 bucks for a $30 set of bearings. Anyway, I put them in and they all measured slightly better by a few 10 thou. Rear cam bearing is still out of preferred spec but much better at .0039 instead of .0043. allowed is up to .006 so I'm just gonna go with it.
Steve
Excellence!
4:54 PM
Got the head bolted down last night. NOS Ford latest design head gasket. Clamped down TTY 50lbs plus 100°. Got this really sweet torque angle meter that sticks to a ratchet or breaker bar with a magnet. Best 100 bucks I've spent on a tool.
PXL_20230203_011939900.jpg PXL_20230203_012011431.jpg PXL_20230203_020059302.jpg PXL_20230203_014520545.jpg
FergusonTO35
5:54 PM
Boonesborough, KY
Between wrong parts and bad weather I'm finally getting our Odyssey back together. Every single part has been fighting me. Wire harnesses that won't move far enough, spark plug tube seals that won't slip over the tubes, even the valve cover bolts won't find their threaded holes without a mirror and a light. It's good to remember why I changed careers!
Steve
Excellence!
4:54 PM
So got some work done on the engine this weekend. Found a set of hard to find fine tooth metal timing gears! Bit of an upgrade from the stock fiber gears. Got another set of NOS rocker arms. Learned on the last engine about poor fitting aftermarket rockers. New pushrods too. Nee oil pump and pickup installed and covered up with another new oil pan. All that's left to do is put some lipstick on this ugly chick!
PXL_20230205_013930221.jpg PXL_20230205_020544090.jpg PXL_20230205_022849814.jpg PXL_20230205_031703820.jpg PXL_20230205_180249582.jpg
Steve
Excellence!
4:54 PM
Bigmac
2:54 PM
That's gonna be a beast Nathan! Which bike is that going in?
This one Steve. Have it completely tore down and am doing a full restoration on it. It had a 350 stroker, now the 390, with a hand cone pipe
FergusonTO35
5:54 PM
Boonesborough, KY
