Redfin
Meh...
- 11:24 AM
- Dec 24, 2015
- Central Pa
Highly suggest some preheat on that center Mikey.
Spill a can of saw gas on the passenger side floor mat, it'll smell like saw gas for a few weeks at least.- oh, and the inside smells like mold. Anybody got a remedy for that?
I have been looking at a vw Jetta with a 6 speed manual for commuting, it's 20 years old as well. 140,xxx miles runs and drives, I know nothing about vw's.Mrs. Geek wanted something better on gas for a goin' ta town rig, so I searched the ol' face-space until I found a 20 year old VW for $1,500. It followed me home, so now to get it road legal and fixed up good enough for a occasional driver. Updates will be coming.
Fixed already:
- Hood latch
- tailgate latch
- wiper blades
- turn signal bulb
- oil change
Need to fix:
- trans fluid and filter (new pan while i'm at it - the old one is rusty)
- air filter
- rear shocks
- front struts and coils (maybe)
- electrical gremlins everywhere - no electronics in the driver's door, no radio even present, 12v. power plug in the dash doesn't work, etc.
- transmission in limp mode - need to pull codes and see what's up
- ABS light is on - need to pull codes and see what's up
- front fender light
- clean the outside
Perfect!Spill a can of saw gas on the passenger side floor mat, it'll smell like saw gas for a few weeks at least.Maybe dump peppermint extract all over the interior? I drive a 94 Land Cruiser that has smelled "musty" for 8 years of semi-regular use, and the smell is just as strong as it was initially if it's 85+ and sunny in the car. I've deep cleaned it and the only result is the smell is mostly unnoticeable until the weather gets hot.
Perfect!
Mrs. Geek sprayed vinegar all around the interior today and scrubbed it. Probably going to need more of that.
FINALLY decided to use the original booster with the Wilwood master, just had to persuade the spring tower a wee bit. Next steps are to bleed the clutch master/slave, then run new brake lines everywhere and install the Wilwood 4 wheel disk brakes. The rear end is held up untill the Detroit Locker arrives. Gears came in, I’ll roll the rear inner fenders, cut off the bump stops, and begin the negotiations for rear tires/rims. I’m looking for 10” rims with 295-315 tires. Prolly settle with upper level management for 9” rims with 275-285 tiresYou can pull the carpet out and pressure wash it.That will get rid of most of it.Perfect!
You’ve won our race, beat me to the finish !!All rebuilt and painted. View attachment 334035
