Grease Monkey Garage
Canadian farm boy
“Normal” people scare me.
9:05 AM
Ontario, Canada
I got the rear end back under my car finally. I just have to adjust everything to center it, set the wheel base and set the pinion angle. And with my luck I now need to have another y pipe made for the exhaust. The new trans crossmember sticks down about 1” lower E327C224-7FBE-48ED-BF36-725656687E36.jpeg177AF491-F250-4B5D-B08A-4FC4E71E96FD.jpegE0AA0336-B189-41F0-99A0-C628A7E6BBCA.jpeg
Moparmyway
Its just a saw
9:05 AM
In a meeting
What size is the pipe that goes from the front to the rear ?
Moparmyway
Its just a saw
9:05 AM
In a meeting
Single 3" outlet, or does it divide into two after the muffler ?
Redfin
Meh...
9:05 AM
Central Pa
Stevetheboatguy
8:05 AM
Nw IL
Dinosaur I know. But have to ask..... Anybody know the proper procedure for setup?
It works I just need to know if there is a first run zero step. To make sure I'm not endlessly tossing weight on and such.
Steven
Yukon Stihl
6:05 AM
Great White North
Steven
Thats the same as my balancer
Yukon Stihl
6:05 AM
Great White North
Steven
So the first knob you can set for normal, weights on the bead,or aluminum1 or aluminum2 which you use either stick on weights or stick on and a bead weight like the diagram.You turn the knob all the way to the right and back of a bit turn right again repete till you have the weight type you are going to use.Then it functions as the width of the rim form out side bead to outside bead
Second knob is wheel size,15-16-17 inch
third knob is the measure of the tire machine to the outside of the bead.That is the l shaped thing you pull out and put the pin on the edge of the wheel.
You will need some adapters to do dually wheels.
Stevetheboatguy
8:05 AM
Nw IL
That's what I thought. Didn't know if it had to do a empty run to zero it out each time or not.
Have very little experience with a balancer. But am happy to add it to my garage. Need to find some time to play with some different wheels and get the procedure down.
Thank you for the input. I may have to pm you if I need further instructions!
Steven
