Woodslasher
Teh debil
- 5:28 AM
- Mar 18, 2021
- Commiefornia
That looks expensive!
So your going to build the original? 7.5?Got a bunch of new goodies to rebuild my camaro differential. I’m hoping to take the whole rear end out of the car this weekend. View attachment 330696View attachment 330697
That’s the plan. I figure on the street with radials it should be fine. When I’m done it should be good for about 500hp. (Fingers crossed).So your going to build the original? 7.5?
Ya with street radials you should be fine! You. Would have to hook pretty hard to be an issue! Have the s60 myself, and It’s honestly overkill, had an 8.5 before without issue, but my dad needed an axle for his 56 bel air so I bit the bullet. The possi is amazing in the s60 but it kinda stupid moneyThat’s the plan. I figure on the street with radials it should be fine. When I’m done it should be good for about 500hp. (Fingers crossed).
I was originally thinking about a S60 or 8.8 conversion but that’s outside of my budget these days
Hey, Derek on Vice Grip Garage is running a procharged big block on a factory 10 bolt in his Independence Chevelle. It will work... till it doesn't LOL.That’s the plan. I figure on the street with radials it should be fine. When I’m done it should be good for about 500hp. (Fingers crossed).
Should weld some 1/4 plate footing so you can bolt it down to the concrete with anchor bolts, then ya can really reef and it wont be moving lolGot weld table flipped last eve. Still need to finish weld perimeter of top to angle.View attachment 330881View attachment 330882
Its getting heavy castors at each corner. Will be mounting fixture at each end with a bottle jack to raise table onto castors.Should weld some 1/4 plate footing so you can bolt it down to the concrete with anchor bolts, then ya can really reef and it wont be moving lol
We have anyone that knows their way around a 4l80e?
Think I just shat second gear in the one I rebuilt this past fall. Think the intermediate sprag let loose.
First gear is good then it revs high tries to engage 2nd, slips then shifts early into third, get up to speed and shifts to fouth fine. Tc engages and disengages as it should. Down shifts fine from fourth to third, third to second is like a double bump. Prob because second isn't there and it's dropping from third to first. Spent all day running a scanner and changing out shift solinoids, accumulators, springs and then finally the whole valve body. No change. No codes whatsoever the whole time.
1998 k2500 suburban 7.4
Steven
A 8-1\2 10 bolt setup right will take a lot of abuse..This is me on a 10:50 pass, the rear end was about 6 or 7 yrs old at this point...Eaton POSI and 390:1 Auburn gear, C clip eliminators\floating Moser axles and good ole Caltracs with mono leafs. It would do this from almost any old stop light. Oh and TH350 with a 3500 TCI super streetfighter..never saw a need for a TH400 or a transbrake..foot brake and SPRAY!We have anyone that knows their way around a 4l80e?
Steven
