Woodslasher
Teh debil
- 2:52 PM
- Mar 18, 2021
- Commiefornia
So you Tight End it?What do you do when you need to torque down a hub nut on a axle, but your torque wrench is 1/2 inch drive and the only socket that fits the nut is a 3/4 inch drive? You improvise!
View attachment 315945 View attachment 315946
Nope, I preloaded it.So you Tight End it?
Sharp eye, that’s an old take-off from either a D4 or D5.My buddy who works for the Highway maintenance here told me they are having a hard time getting those blade bolts
They do make 1/2 to 3/4'' adapters ......What do you do when you need to torque down a hub nut on a axle, but your torque wrench is 1/2 inch drive and the only socket that fits the nut is a 3/4 inch drive? You improvise!
Had some small stuff to work on with the camaro, had a squicky rear brake, a bolt came lose after 6+ years, took it on a couple solo cruises, and some good miles on the gmc
Cam specs?Had some small stuff to work on with the camaro, had a squicky rear brake, a bolt came lose after 6+ years, took it on a couple solo cruises, and some good miles on the gmc
What is your LSA?Solid roller, 256/260° at .050 .615 lift it’s a isky, billet with a cast distributor gear
That’s pretty awesome Steven! Will be fun!I'm bringing the late 80's early 90's back..... Where's my mullet!
View attachment 327777 View attachment 327778 View attachment 327779 View attachment 327780 View attachment 327781
Not to shabby for less than a hour and a ten year old pint of rustolium. A good test run before the real body work happens.
Steven
