Woodslasher
Teh debil
- 4:12 AM
- Mar 18, 2021
- Commiefornia
Striving for perfection.A bit of sanding later I had this:
View attachment 307360 View attachment 307361
I'm also redoing the bondo in a really bad spot, this time using a long board.
View attachment 307362 View attachment 307363
And lastly, the height difference between my truck and my brother's.
I love it.
Glad you bumped this thread back up. I've been meaning to make a post here from my other one on Steve's Ford resto thread.
Any Dodge owners with the square body style out there interested in a wood grain dash bezel LMK.
Have one from an 89. Lookin to find a good home for it.
Pay it forwards.
Looks like a family toboggan.Bishes....... Ima hav to reload muh piks
As previously stated. No Lift..... No Problem
View attachment 307575 View attachment 307576 View attachment 307577 View attachment 307578
Steven
Nice job CFB! Plumbing and wiring used to be my one of my favorites.Harness is about done, I just need to tidy it up a little more. I’m almost ready for some tuning. View attachment 307601View attachment 307602View attachment 307603View attachment 307605View attachment 307606
You gonna be on the West Coast any time soon? I've got some wiring gremlins that need to be tracked down and I *frenching hate wiring!Nice job CFB! Plumbing and wiring used to be my one of my favorites.
Attention to detail can make or break a project.
I'll take a drive over after I finish my roof job...... seriously wish I lived a bit closer to help ya out.You gonna be on the West Coast any time soon? I've got some wiring gremlins that need to be tracked down and I *frenching hate wiring!
There’s so much info online these days for these types of swaps that it makes the wiring almost easy.Nice job CFB! Plumbing and wiring used to be my one of my favorites.
(As I recall) "Everything" at the taillights works when the running lights aren't on, if you turn on the running lights they don't actually come on in the rear, but the brake lights no longer work.I'll take a drive over after I finish my roof job...... seriously wish I lived a bit closer to help ya out.
Wiring gremlins in them old fords is usually tracked down to faulty grounds.
What er her symptoms?
There should be a harness plug under the cab that separates the rear from the rest of the wiring. Unplug it there and check for all your functions at the plug using a basic test light. If all is good there, inspect the rear section for any fraying and pinching. I would pay close attention to the body grounds.(As I recall) "Everything" at the taillights works when the running lights aren't on, if you turn on the running lights they don't actually come on in the rear, but the brake lights no longer work.
Two notes:
#1: Everything on the front half of the truck (save for the roof lights) works a-ok, everything I mention is solely in reference to the taillights
#2: The reason everything is in quotes is because while some bulbs light up every time you hit the brakes, flashers, put 'er in reverse, etc, I don't think the lower lights (clear lens) ever came on. This is all based off of slightly foggy memories from a month or so ago, so I could be wrong.
Oh yeah, I forgot a few things.There should be a harness plug under the cab that separates the rear from the rest of the wiring. Unplug it there and check for all your functions at the plug using a basic test light. If all is good there, inspect the read section for any fraying and pinching. I would pay close attention to the body grounds.
I agree, your health 1st.Oh yeah, I forgot a few things.
First, the rear harness may have been accidentally, partially pulled into pieces when the bed was pulled. It was carefully spliced together as best as I knew how, but the p.o. had hacked up the rear harness a wee bit. I think I got everything fixed correctly, but I'm not 100% confident on that.
Second, I checked the rear harness while it was out and repaired any and all frays I saw.
Third, I will do a test light thingy soon, but between college classes and feeling pretty crappy from coming off of the meds I got at the hospital I've been avoiding doing any sort of physical, outdoors work. I'll be sure to report back when I do get around to tinkering on the trucks again.
