Ferguson tractor Z134 valve job
FergusonTO35
11:19 PM
Boonesborough, KY
Ugh, that looks like fun to deal with! What is that off of? I think the hardest part on the tractor is over, now it's just a matter of fixing little long-neglected bits and getting everything dialed in.
Steve
Excellence!
10:19 PM
My Zetor 5211
FergusonTO35
11:19 PM
Boonesborough, KY
Looks like a good old machine. There are a fair number of them around here even though I don't know where any dealers are. I think some of the 90's Agco Allis tractors were Zetor rebrands.
Steve
Excellence!
10:19 PM
Those where SAME of Italy. We have one of those too. Agri-power 5000 and 7000 where Zetors. John Deere 2000 series in south America where Zetors.
11:19 PM
I think that's just typical .My two Fergies get black plugs but for some reason Ollie the OC6 crawler does not and all three have Marvel-S carbs .Then come to think of it Ollie had a complete carb rebuild and the other two have not .
I had mentioned the float needles have a tendency to stick every so often .Weather the needle with a rubber tip would be better I really can't say but it only takes a tiny speck of of dirt or rust to cause them problems .
FergusonTO35
11:19 PM
Boonesborough, KY
I leaned it out a bit and runs alot better now. Mowed some with it yesterday and did great. I adjusted the rod from throttle to governor to give a bit more tension, now it holds rpm better. Still going to replace the cork disc when I get a chance.
legdelimber
11:19 PM
N.C.
Any chance that you could cut a friction disc (or two) from some of that stiff brown, fibrous gasket stock and use it in the throttle lever pivot?
FergusonTO35
11:19 PM
Boonesborough, KY
Ok, got the new cork friction disc installed. The old one was brittle and slick, no surprise it didnt work well. I went ahead and cleaned and greased all the pivot points of the throttle and governor mechanism since it had to come apart anyway. Buttoned it back up and mowed for a little while and she is running great!
Steve
Excellence!
10:19 PM
That's great to hear!
