Philbert
Chainsaw Enthusiast
- 6:07 AM
- Jan 30, 2016
- East Dakota
Have you thought about cryogenic treatment of the Delrin?
Philbert
Philbert
Philbert
BTW, the Acetal/Delrin rollers are holding up very well!Replacement bottom rollers, 10mm acetal/delrin plastic rod off eBay center drilled and cut to length.
View attachment 275848 View attachment 275849 View attachment 275850
I don't need the raker-roller too often anyway, but had I not lost one of the worn out rollers I would have cut off the tooth-roller section and reused the raker-roller section basically making a two part roller.
The raker-roller section sees much less wear than the tooth-roller section!
Huh, I completely forgot about this idea!Yeah, I'll just replace them when they wear out.
I have an idea for "renewable" bottom rollers, but I need access to a lathe.![]()
VERY impressive!Cut out with an angle grinder (next batch I'll let the mill bit go deeper so there'll be less material left)
Further processed with a bench grinder and a Stihl flat file
Not bad at all, they are a little bit longer but the mounting screws have enough length to accommodate them.
Mr. Philbert, I like Your thinking!VERY impressive!
Could you cover these with some tape or heat-shrink tubing now to protect the files against unnecessary wear on the metal? Maybe make the rollers slightly undersized and cover them with sacrificial tubing, rather than replacing the rollers each time?
Philbert
I have some heat shrink tubing, I will look whether I have a diameter to actually fit the bottom roller OD.VERY impressive!
Philbert
