Cerberus
Cerberus the aardvark, not the hell-hound!!
- 6:38 PM
- Jan 20, 2020
- Florida (tampa area)
To be crystal clear...this ring comes-with, and is part-of, the intake manifold assembly. You'd re-insert it by removing the ring, inserting the rubber 'male' through the plastic wall 'female' and, from the far side, insert this metal ring?Once the ring is removed the boot can be "gently" forced out of the hole. Like a rubber grommet or plug.
Sent from my SM-S767VL using Tapatalk
I just want to be certain, the youtubes I have on this skip-over this part of dissembly/reassembly assuming everyone's taken apart cylinders before....have worked on pretty much everything else, many dozens of times, but never the p&c or crankcase...so stoked to do this especially with how easy it is grinding aluminum especially this large
