- 3:01 PM
- Jun 5, 2016
- Northwoods of Wisconsin
Here's my take on a Echo CS590. Was laid out different from most saws in that it had a lot of intake and not a lot of exhaust duration. Here's it is by the numbers and how I worked through it.
Numbers as found;
Squish-.042"
Exhaust-112*--136*D
Transfer-129*--102*D
Intake-79*--158*D
Seeing that the intake was already as low as it is, I decided to leave the band alone and just tighten the squish. So I removed the gasket and machined .009" off the base to take the squish down to .020". Now to see how that changed it:
Exhaust-115*--130*D grind up to 1.160" from band and widen to 65% of bore diameter
transfer-131*--98*D grind up to 1.285" from band
Intake 81*--162*D leave alone
You can see by the comments after the numbers of which way and how much I decided to go. Lets see where that got us.
Exhaust-106*--148*D
Transfer-125*--110*D
Intake-81*--162*D
Timing advance 6*
Along with a healthy muffler modification this made it a much more powerful saw from new and capability of a pro saw.
Hope this gives someone out there some direction on doing their own.
Numbers as found;
Squish-.042"
Exhaust-112*--136*D
Intake-79*--158*D
Exhaust-106*--148*D
Intake-81*--162*D
Timing advance 6*
