echoshawn
Blinker fluid
- 4:55 PM
- Jan 9, 2016
- Woods of North Idaho
Bumped up to 180#
Now we'll see if it runs
Ummmm, yeah..
You win.
Mine isn't worthy lol
Bumped up to 180#
I can sell ya a 500. Lol. Put the 490 plastic handle on it and boom. YOUR set!The 490 is the lightest 50cc saw I have handled. I haven't had a chance to run one yet.
Looks great Red.
What were your final numbers?
Another comp reading after the run?
I'm slacking. Between work and Easter, not sure I'll be done for another week or two.
@wigglesworth can you explain this.106 on the ex 125 on the transfers, and 76/88 on the intake.
I will try and grab another comp reading tomorrow before I head out of town for work.
This saw would be hard to beat if it could spin up around 14k. Should have checked it without the air filter. High needle all the way in 13k max. Like it hits a wall.
Didn't get a full tank through, but did quite a few long cuts, didn't notice the tune wandering for the high comp, so that is a good sign.
Saw seems to clear noodles really well too.
Ummmm, yeah..
You win.
I'm sorry guys carbs are still one if my weeknesses. Wiggs and poleman are very good with them@wigglesworth can you explain this.
I talked this over with wiggs and he tried to explain it. He didn't have the carb in hand of course. But it's something to do with the carb having dual feeders to the high side so it's actually governed.
I'm hoping to figure out a way to sand bases that are not flat, without having a lathe.Nah, you did fine with what ya had to work with, hard to get much more than 20-30 psi without cutting the base.
Well keep me posted!Supposed to flow roughly 85% fuel fully closed.
I bet dropping the bottom ring would be worth a couple hundred rpm in a gtg saw.
I have 2 14.25mm carbs and a 14.6 zama coming, gonna try my damdest to get more air through this fella.
Well if u can't find a carb there's a way to bypass the dual feeders so u can lean it out. But i don't think it'll make the saw faster for say. I think your on the right track with a bigger venturi.No worries man, shoot, I couldn't hardly tune a carb 6 months ago. So I hardly know anything bout them, but I am good at cobbling things to get what I want![]()
How did you come up with 125? Is that same amount you take from exhaust roof. 6 degree131 after is cut the base, set them at 125 in the finished pic.
It's got nothing to do with it.How did you come up with 125? Is that same amount you take from exhaust roof. 6 degree
Just trying to learn. Not questioning your work by any means.
I'm wondering if it's the crappy air filter.
Anyway the coil is limited? Would the breaking up sound like 4 stroking? I've never ran a limited coil saw.
I'm still trying to understand what creates rpm per se. What makes one saw 4 stroke at a higher rpm than others.
I had this problem on a recent 026 with an 044 carb. Saw was stuck in the 13's no matter what I did, even with the large Venturi. I finally popped the air filter and the saw jumped 3000 rpm.
Again, I've managed 16,000 from a 194 on an 026. The same size Venturi as this carb.
I took a bit more than you did off my base red. My squish is a bit looser. I'm hoping my comp is no higher than yours.
Yeah those flock oh26 filters suck. Mine is stuffed with foam at the moment till I can get one of the winter mesh filters topped with pantyhoseI'm wondering if it's the crappy air filter.
