Echo cs 490 porting
10:30 PM
I didn't go popup. Did I mention how much I hate dome Pistons?
My stock squish was .047 without base gasket.
I took .060 from base and .037 from band. I have a final squish of .023-.025. Unfortunately, the thicker reading is by the piston edge.
ImageUploadedByTapatalk1458423148.945688.jpgImageUploadedByTapatalk1458423163.818827.jpg
Red97
10:30 PM
MI
I went 7* for the band. Make sure if you are cutting with a mandrel the tool bit is cut short enough... :(
Those 2 gouges by the threads were before I realized the tool bit was too long. Made a sanding mandrel at 7* and finished to 150 grit.
Ex at 106, still have to bevel.
Transfers on the way to 125.
I am about .053 off the base, and .018 squish. Went too deep, and had to cut more off the base.
Red97
10:30 PM
MI
After cut numbers
Ex 121
Tr 131
In 88 at the very point.
Think I'm just going to widen the top 2/3 and raise it back up the .050.
echoshawn
Blinker fluid
10:30 PM
Woods of North Idaho
Are you gonna epoxy the bottom of the intake?
Since I pulled my jug I put some in the bottom of mine.
Gonna raise my exhaust a bit and slightly widen the intake.
Red97
10:30 PM
MI
View attachment 15919View attachment 15920
Nice, didn't see much room for a popup either.
Really wish the casting had more meat round the exhaust.
Red97
10:30 PM
MI
Don't think I am going to epoxy mine, just raise it back up, and widen it a bit.
echoshawn
Blinker fluid
10:30 PM
So I raised my exhaust a bit.
Used some JB stick epoxy to raise the floor of the intake some.
And lightly raised the transfers some.
I'll bolt it back together tomorrow along with cutting the new port cover out and see what happens!
Red97
10:30 PM
MI
Your exhaust port looks sad.
Adds character...
You cut your chamber on the lathe? On any angle? I really ought to try using the lathe to cut squish at least once.
Should wake up a bit. Nice job sir.
Don't know if it is easier or not, but I haven't even bother tacking the transfer covers off yet...
What ever they are made of is really soft, cuts quick.
echoshawn
Blinker fluid
10:30 PM
Adds character...
Thank you sir.
I figured if the intake fill kills it, it's easy to grind out.
Have to admit I have cheated a bit.
Messaging with Randy E and Carl some so I don't destroy it.
Although, super cheap find.
bikemike
9:30 PM
Cottage grove mn
Thank you sir.
If people didn't cheet in Nascar, they wouldn't win
