Echo cs 490 porting
9:23 AM
Stuck at 13,500. With air filter, without air filter. Leaner, richer. For richer, for poorer, etc....
Do you think it gained?
bikemike
8:23 AM
Cottage grove mn
It's the coil. In the cut it sounds like it has much higher rpm then the vid without carb mod. I'd leave it for a bit and burn a gallon or 2 through it then do another vid. I se a difference or hear the difference. Wish echo was like that stock. Hits rev limiter very fast from idle
Backtroller
8:23 AM
Land of Badgers
It's snappy and doesn't sound like any other echo I've ever heard. I think that is impressive. It really cut through the big wood nicely.
1.5 seconds is a big gain. Wonder what it gained over totally stock form?
9:23 AM
I think I got a 32.45674328765% gain.
Red97
9:23 AM
MI
Well here goes. I'm guilty of not taking the time to tune in wood. Had 4 stroking, not as much as before. Feels faster, possibly less torquey than the smaller Venturi when the RPMs drop. Possibly.
Can anyone guess Max RPMs? It was the same with our without air filter.
Unfortunately, my fast tach doesn't lend well to being mounted to a saw. It did some weird stuff at max rpm.
After carb mods:
Oak Block
12" log
It definitely, likes the bigger carb. Now I got some more research to to do to find a suitable coil replacement...
Very through work sir.
Red97
9:23 AM
MI
I'm thinking
air filter modification
bar/chains .325×7×8 18" 3/8×7 16" and picco×7 16"or 18"
Then move onto carb mods.
Anything else you guys want to see tested, or tried?
9:23 AM
Unloaded, my saw stays at the same 13,500 with or without the air filter. It didn't do that before the carb mods, it had dropped 500 rpm with the filter prior.
The unlimited coil sounds interesting. I'm wondering if the limited coil may be why this saw doesn't want any timing advance.
If the saw isn't turning more than 13,000 with the bar buried, will an unlimited coil make it any faster/stronger?
9:23 AM
I have metal mesh here, so an AF mod should be easy. I'm wondering if the AF cover needs to be vented Red.
I have a 16" bar for a Husky 346 in .325. I also have a 14" echo bar in 3/8 LP- waiting on a sprocket.
I'm working for the next 9 days. May have a break in the action on Sunday to play.
