Deciding what to build
Which build?
  • An OG 046
    Votes: 5 21.7%
  • Ms441
    Votes: 3 13.0%
  • Ms440
    Votes: 2 8.7%
  • A hybrid (specify)
    Votes: 13 56.5%
  • Total voters
    23
10:46 PM
Matt, you basically just swap the piston & cylinder on a 12 mm 044 or 440. Cylinder needs mods to fit.
The muff dimensions are exactly the same, but when you put a 460 cyl on a 440 base, the bottom of the muff needs spacers.
Getting it to run up to potential involves other secrets.
TreeLife
I'm Dominick
10:46 PM
The mysteries of the hybrid remain just that to me. I'd like to believe I could learn, however. I am a relatively intelligent man with a fantastic memory.
T.Roller
10:46 PM
Southeast, TN
Fitting a 046 jug to the 044 case is very simple. I didn't have to trim any fins. Took a little off both sides of the base and a little off the transfers to clear the flywheel. Also opening up the holes that's it.
paragonbuilder
10:46 PM
Norwich, CT
A longer rod will not increase your stroke, the crank determines the stroke, the rod length will just change the location of the piston (and rod angle).
No, but it will change timing slightly and mean less machining of the base
