- 1:50 AM
- Dec 29, 2015
- Ontario, Canada
There's a few build threads I found here and over there... haven't found a ported 441 specific thread though.. [emoji53]is there a particular thread on how to build a hybrid 440 / 046?
I sure am. Slacking big time any more.slacker
see comment above
ill take it off yer hands in pieces....or walk you though the easy rebuild of one...don't listen to those slackers above....they're husky boys anyway. open up the muff and they wake up nice. the only oddball thing is the throttle linkage and the tank/handle. easy peasy once ya done it. now me, put a husky in front of me and I break out in sweats. 441....no probl.
Slot bolt holes to match 44 gasket. Drill the holes through the fins if you have impact tools like mine as they won't fit without binding. Trim plastic under top cover and muffler spacers for the lower bolts.looking for 044/046
Working on saws all the time got to be no fun and a big chore I had to force myself to finish them. Still have a couple to finishkids and aging will do that to a young guy....priorities change.
wait till you get to be my age....you can't even remember what you were "interested" in...before you need a nap to decide....
then its sleep time....and next day comes.........rinse lather repeat....
just to ask the question again, because I think it got missed, is there a particular thread on how to build a hybrid .... or what it takes to build one?
The hybrids seem to be a bit smoother than a 044 or 046's I've ran. Part of it depends on who ported it, good or bad AV mounts, how much compression and how agressive the chain is.Power to weight is important to me, on a 10 hour day logging I probably have the saw in my hand for 8 hours. Im not super vibration sensitive but if the saw is a real rattle trap I suffer, having broken many bones in the past is a real downer!
Chain is always a determining factor for vibration. When felling I tend to leave the rakers higher and not gouge out my gullets so I can do bore cuts more smoothly. On the landing bucking? Just the opposite, I want that big ole landing saw to eat!The hybrids seem to be a bit smoother than a 044 or 046's I've ran. Part of it depends on who ported it, good or bad AV mounts, how much compression and how agressive the chain is.
I don't think he did and said he wasn't because of the *B-S.... @PA Dan was building one at the same time and was a shared threadIf my memory serves me right Jeremy @Adirondackstihl was working on AS when the big meltdown happened and most of is wandered over to this place. I don't know if he ever finished the thread or not after Darin changed his avatar to a steaming pile of pooh...
That was a great thread!I don't think he did and said he wasn't because of the *B-S.... @PA Dan was building one at the same time and was a shared thread
