Clint's Hybrid
10:20 AM
7900 is hard to beat. I still think a 372 is the one to beat after a 7900.
I've run a screaming ported 372, but it had a 20" bar on it. I'd love to compare the 372 & 7900 to the 460/046-D Randy did for me, but with the longer bars.
In general the Hybrids are also "faster" than the 460, but don't have as much torque. I've never run a ported 7900, but both the Hybrid & 7900 have a lot of displacement for their case capacity, which likely results in a very fast saw.
10:20 AM
That's impressive to be able to do that, 395 is quite a bigger saw!
Yep. Chain was the same if I remember right. I usually use the 34" so I don't have to adjust the mill.
MG2186
9:20 AM
Summer,IA
That's what makes what you guys do so interesting! Making more power with anything is that way, far from just a cut and dried formula!
Rains
9:20 AM
N Illinois
always interesting about how these builders test and think about each saw they build.
cgraham1
7:20 AM
Nor Cal
Randy, which flywheel did you end up using on the hybrid?
