- 7:48 AM
- Dec 29, 2015
- Ontario, Canada
Each of my grinders is mounted on a simple wooden base that can be clamped to any flat surface, and removed for storage, or for use elsewhere (I like to grind outside when weather permits). A potential problem with a swivel base is that it would still be taking up space on your bench.I'm wanting to mount one of my grinders on my bench. But the grinder will stick out. Could a person mount it on a swivel base, to turn it around when not in use?
That is why my 511a base is designed to let me clamp it to a step ladder - height adjustable and portable!Grinders really need to be higher than a work bench.
Nice. Simple. Effective.I have my grinders mounted to a 2x4 that I clamp in my bench vise.
I like my grinders mounted down.
I like my grinders stationary.
What do you think of a boat seat glide. I just need away to back them away from people or myself running into them.Easy to make a rotating base, with a piece of 3/4" plywood and a bolt through the center. Have a second hole at the side, where you can drop another bolt (and maybe a wing nut) to lock it in place. These are not very large or heavy machines.
OR, mount it on a platform with drawer glides, with a thumb screw to lock it in place. Or place the entire section of workbench on drawer glides to slide in and out.
OR, mount the grinder(s) on a hinged piece of wood that lets you tilt it back, out of the way when not in use. Add a hold down bolt, latch, chain, or bungee cord as desired.
Most of my grinders require access to the bottom for vise rotation.
Philbert
That could be a good, ready-made hardware solution. I like the spring-loaded latch.What do you think of a boat seat glide.
Hope y'all understand what I'm trying to do. I just need away to getem out of the way.That could be a good, ready-made hardware solution. I like the spring-loaded latch.
Philbert
Can I get my chair under it?This is a cheap (not nasty) non permanent way of setting up a grinder outside that is perfect height for me. I was going g to make a stand out of an outside umbrella base/stand but this works so well I just keep using it. 1X stepladder 2Xirwin quickgrips. View attachment 44830
Does the swivel lock?Hey @Icepick69 i was at a buddy's the other day and he has a pretty heavy TV mounted to his wall, on a swivel mechanism that moves in all kinds of directions, google it and see if any may work!!!
Who's house were you at? Why didn't you stop byHey @Icepick69 i was at a buddy's the other day and he has a pretty heavy TV mounted to his wall, on a swivel mechanism that moves in all kinds of directions, google it and see if any may work!!!
Lol, I was at my "biker" buddy's house....he is crazy, so am I, we used to have ALOT of fun LOl.... I went over there with the woman and kid the other day.... 5-years ago a permanent woman and a kid was just a crazy thought.... wow have I settled down, some LOL!!!!!Who's house were you at? Why didn't you stop by
