Chainsaw grinder questions, tips, tricks, and pics!!!!
Philbert
Chainsaw Enthusiast
7:06 PM
East Dakota
I'm wanting to mount one of my grinders on my bench. But the grinder will stick out. Could a person mount it on a swivel base, to turn it around when not in use?
Each of my grinders is mounted on a simple wooden base that can be clamped to any flat surface, and removed for storage, or for use elsewhere (I like to grind outside when weather permits). A potential problem with a swivel base is that it would still be taking up space on your bench.
A few guys have screwed wood or metal cleats to the base of their grinders to clamp them in a woodworking or machinists' vise for temporary use.
(EDIT : was typing my response when Canadian Farm Boy was posting the photo above! Great minds . . . .)
Grinders really need to be higher than a work bench.
That is why my 511a base is designed to let me clamp it to a step ladder - height adjustable and portable!
Using a piece of Unistrut, or a piece of pipe and a pipe clamp, you could also make a height adjustable post for use at a conventional work bench.
Philbert
Icepick69
Fart knocker extraordinaire.
8:06 PM
North Carolina
Something like this is what I was thinking about, but there expensive. I need two.
I like my grinders mounted down. And I have a section of my bench I don't use. But they stick out on it. So I would like to be able to swivel them around.
Thoughts- good and negative please.
Jimmy in NC
8:06 PM
North Carolina
Honestly sounds like you have your mind made up and are looking for someone to say "Wonderful Idea!"
I think you will find they are still in the way and the rotation will get seriously gritty under a grinder. Only you know what works for you though and every shop and person are different. That's why everyone organizes their desk / tool box / kitchen / etc their own way.
Icepick69
8:06 PM
North Carolina
No im not looking for ( wonderful idea) I would like a swivel base that will work without spending a lot of money for it.
I'm hoping someone has the ( why didn't I think of that idea) cheap and easy.
I like my grinders stationary.
Philbert
Chainsaw Enthusiast
7:06 PM
East Dakota
Easy to make a rotating base, with a piece of 3/4" plywood and a bolt through the center. Have a second hole at the side, where you can drop another bolt (and maybe a wing nut) to lock it in place. These are not very large or heavy machines.
OR, mount it on a platform with drawer glides, with a thumb screw to lock it in place. Or place the entire section of workbench on drawer glides to slide in and out.
OR, mount the grinder(s) on a hinged piece of wood that lets you tilt it back, out of the way when not in use. Add a hold down bolt, latch, chain, or bungee cord as desired.
Most of my grinders require access to the bottom for vise rotation.
Philbert
Icepick69
8:06 PM
North Carolina
Awesome, love the drawer glides. Thank you. One of my grinders is very heavy and I'm worried that I will eventually drop it. But I'll look into the drawer slides and see if it will support the weight.
Excellent idea and thank you very much.
Icepick69
8:06 PM
North Carolina
Philbert
What do you think of a boat seat glide. I just need away to back them away from people or myself running into them.
Jimmy in NC
8:06 PM
North Carolina
I think @Mastermind made a grinder mount out of a bicycle fork and frame section at one point. It may not have been him.. I'm digging in the way back memory bank. It was for a similar situation, they needed the grinder out for use but out of the way most of the time. The steering stem bearings were the pivot assembly.
Icepick69
8:06 PM
North Carolina
That could be a good, ready-made hardware solution. I like the spring-loaded latch.
Philbert
Hope y'all understand what I'm trying to do. I just need away to getem out of the way.
And if anyone has a solution on how to get people to quit touching your square grinding wheel. I'm all ears. Lol
CR888
10:06 AM
Australia
This is a cheap (not nasty) non permanent way of setting up a grinder outside that is perfect height for me. I was going g to make a stand out of an outside umbrella base/stand but this works so well I just keep using it. 1X stepladder 2Xirwin quickgrips. 1481926055811.jpg
Khntr85
8:06 PM
Indiana
Hey @Icepick69 i was at a buddy's the other day and he has a pretty heavy TV mounted to his wall, on a swivel mechanism that moves in all kinds of directions, google it and see if any may work!!!
Icepick69
8:06 PM
North Carolina
This is a cheap (not nasty) non permanent way of setting up a grinder outside that is perfect height for me. I was going g to make a stand out of an outside umbrella base/stand but this works so well I just keep using it. 1X stepladder 2Xirwin quickgrips. View attachment 44830
Can I get my chair under it?
Khntr85
8:06 PM
Indiana
Who's house were you at? Why didn't you stop by
Lol, I was at my "biker" buddy's house....he is crazy, so am I, we used to have ALOT of fun LOl.... I went over there with the woman and kid the other day.... 5-years ago a permanent woman and a kid was just a crazy thought.... wow have I settled down, some LOL!!!!!
