Chainsaw grinder questions, tips, tricks, and pics!!!!
singinwoodwackr
12:19 AM
moon
Have you cut with one of those chains yet? I find rakers on the grinder to be a tricky business and not that bad to just hit them each a stroke with the file.
Thats fine for an occasional chain that just needs touching up. Try doing 20 rocked chains at a time…🤪
I finally broke down and ordered a course flat cbn raker wheel to replace the regular cbn wheel I’ve had for a couple years.
president
11:19 PM
peachland BC Canada
I have a tappered cbn one for my usg. Wont the flat one cut a flat surface ,and make for a jumpy
chain?
Junk Meister
1:19 AM
Nebraska
I do the far side cutters, & flip the chain around
so that the wheel approaches from the low side first
to avoid the chatter .
Do you put a relief/slant angle on the forward side of the rakers? Then you need to flip the head "X*" degree when you flip the chain.
I have the grinders but have yet to get them set up.so most likely overthinking things.
EFSM
1:19 AM
Extreme southern IL
Is the reason rip chain is around 10° because the finish is better? Or is there a durability or speed reason?
Cutting across vs with the grain are two completely different animals. I don’t have experience with using ripping chain, only in sharpening it, which is usually at 10*.
2:19 AM
Standard chain works fine for crosscutting, noodling, and milling.
Milling chain lasts a little longer (because of the 80° side plate cutting angle ) but cuts slower while leaving a better finish
Lawless
2:19 AM
NW NC
So the only reason to change a chain to 10° for milling would be better finish? Otherwise standard chain is just as good?
Junk Meister
1:19 AM
Nebraska
Bob L has/had a many page thread over on AS
one comment was kind of an answer.
Don't waste a chain away by sharpening it all at once. Gradually change the angle each time you sharpen it. That was about using a standard chain and converting it to a RIPPING chain Cheaper and so many pointers in that thread.
8:19 AM
I did it that way with my 36" setup, 5 or so degrees every other grinding.
That loop is now dedicated for milling, and a new 115DL loop went into rotation as a bucking chain.
president
11:19 PM
peachland BC Canada
well said!
Philbert
Chainsaw Enthusiast
1:19 AM
East Dakota
I often set my depth gauges with the grinder, for height, then round them over to the factory profile using a ScotchBrite deburring wheel.
Eliminates possibility of a sharp corner digging in.
Looks OEM.
Others use a file, Dremel type tool, bench grinder, . . .
8:19 AM
Looks OEM.
I use a small OD pink stone in my straight shaft/dremel type grinder on filed rakers.
Or recently, I grind them at a 70° angle and leave them as they are.
Philbert
Chainsaw Enthusiast
1:19 AM
East Dakota
Some guys mentioned, over the years, profiling their depth gauge grinding wheel concave, to adjust height, and shape them, at the same time.
Sounds like a good idea. Never got around to trying it.
Philbert
Lawless
2:19 AM
NW NC
I sharpened a very nice like new 91DL 3/8 chain I found in the “box o chains” I inherited from my FIL. It had a little rust in 2 places but otherwise is GTG.
So all of my 28” chains are done and perfect.
I believe all the 25” chains are done too.
20” I think I have one left.
All of the .325 chains for the 261 are done.
I figured out that there is a little play in the grinder at the pivot. I use this to my advantage. I can come straight down and do the main cutting and then flex it to the left slightly and just barely kiss the cutter and it removes the burr perfectly 😎
2:19 AM
Other than the side plate staying sharp a little longer being at 80°, yes. Standard chain works fine for milling, noodling, or cross cutting
Lawless
2:19 AM
NW NC
I have a guide that rides on a 2x6 to try and I plan to buy an adjustable one that rides on rails or a ladder. I want to make a few things and give it a go.
I watched a video last night of guys in Russia building a cabin, they made a lot of lumber with no guide and a MS250. Was really interesting.
2:19 AM
There are a lot of members that enjoy messing around with it. Good for the soul, creating something usable and watching your progress as you move forward. It requires a big saw typically, but anything is possible if you can keep it running cool and well lubricated. The general rule is 70 cc minimum, but I have found the torque to be quite a bit better on 90+ cc
