mrxlh
I stayed late and finished!
- 2:19 AM
- Dec 2, 2020
- Dat Boot
The shelf standard offering CBN might not be your best option, Baltic abrasives will make any wheel profile/material/grit you specify. That said, chain damage and how you prep the chain affect results greatly. I have had very good success with the standard CBN offering wheels. I do have enough loops as well as a great way to clean them that I never have to push a chain where it is dull enough that I need to take big swipes and risk burning a cutter. If I rock it, I just fast grind each side 2-3X to get it even without burning a cutter.I am not a fan of the CBN wheels. I know that makes me an outlier.
I did not like the finish I got with $100 wheels off Amazon. I could still overheat a cutter, if not careful.
I don’t have a problem with good quality vitrified wheels, *** as long as they are regularly dressed *** (lightly, once per loop).
I can shape them for custom profiles. I can get them for $15 each (or free from guys who buy CBN wheels!).
They do produce more dust, but I try to grind outside.
Some guys report better results with better brands of CBN wheels, but not likely the cheapest ones.
Philbert
