- 4:35 PM
- Apr 28, 2016
- Croatia
Had the ax heads wedge been slightly wider that would have cracked open all the way.
Those are easy, they crack when hit smack down the middle.Burled White Oak.
Close to impossible to split by hand.
I have TONS more of it to cut.
I was just saying that those can be split, I meant no disrespect!Yeah... Ok.
I've been splitting wood for 45 years (started when I was 11).
Probably one of my favorite patternsDid you see this yet?
Axe? Oh I see it knowDoes this axe look bigger then normal?
NICE! Vintage Lightly Used Council Tool 5 Lb Dayton Pattern Single Bit Axe Head | eBay
Find many great new & used options and get the best deals for NICE! Vintage Lightly Used Council Tool 5 Lb Dayton Pattern Single Bit Axe Head at the best online prices at eBay! Free shipping for many products!www.ebay.com
I also don't understand those double bits, unless for felling trees with an ax.There’s all different styles, but axe heads a more slender design for splitting and chopping, normal rounds View attachment 374147but not all ,View attachment 374148View attachment 374149
Bingo!I also don't understand those double bits, unless for felling trees with an ax.
Can you cut kerf deeper in handle at least 3/4 deep of head , shave a little off handle, resink a wider wedge, glue it in and a barrel wedge if you have any ,Skinny there on the left is getting loose on her handle…what say ye axeperts? I have sunk the wedge deeper a couple times. I was gonna wiggle the head up a little, sand the shelf out, and try to sink the head deeper on the handle.
Just an example , so the handle is above head 1/4 - 3/8 “ . and handle is splade outward above head when you set wedge in , and barrel wedge it .Skinny there on the left is getting loose on her handle…what say ye axeperts? I have sunk the wedge deeper a couple times. I was gonna wiggle the head up a little, sand the shelf out, and try to sink the head deeper on the handle.
