Another chainsaw dyno...
Dieselshawn
12:33 AM
Southern Ontario, canada
Tuned pipes are strange contraptions....
I love tuned stuffs. Practically everything I have is tuned for powa!
John Deere 2130, stock 60 hp, now 80 hp
Dodge Cummins 12v, stock 180 hp, now 500 hp
Freightliner truck, stock 475 hp, now 575 hp
Then several of my chainsaws :D
Nutball
11:33 PM
Mt. Juliet, TN
Joe, do you dyno a saw with muffler mod before porting, so you can see what your port work did? That's usually my approach, so I can see gains (in wood for me) with muffler mod, then gains from porting, then gains from compression.
Red97
12:33 AM
MI
How do you remove or put on clutch cover? Remove the pipe?
Doesn’t even look like it would fit underneath the pipe in that photo
It's tight, but it fits and can tighten the bar nuts.
With these pipes just 1 spring keeps them attached to the header flange. Easy to pull the spring and slide the chamber off quick.
No, not unless it comes in with a muffler mod.
I normally do stock, then fully ported.
Lot just depends on the saw too. The 20% gainers 5-10% could be muffler alone.
Red97
12:33 AM
MI
One spring for pipe removal and install sounds 75% easier than trying to remove four loctited bolts just to get the cover off. :D
Make sure you have the hook tool to pull the spring off.
Even the backside of cutters and rakers will do a number at full force...
Dieselshawn
12:33 AM
That’s true too.
The hook tool is pretty common also for snowmobile exhaust systems. Some of them have 28 springs holding their pipes in place.
