Another chainsaw dyno...
Red97
3:02 PM
MI
So these numbers are "close" not ready to call it calibrated yet.
But all run right after each other shows pretty good.
Top 2 lines are the same saw. A mild 50mm echo hybrid.
Then a ported 620pw
Last is a bone stock echo 620p
Waiting on tech support to help dial in the calibration
Red97
3:02 PM
MI
This ^^^ is a cfb hybrid 044 vs the stock 660 I have. The 660 showed pretty much the same 7.1hp as it did on the other setup.
And here ^^^ we have the last dyno buster.... 3 runs back to back showing the same 9.9 ish hp as the last setup.
The runs are close but not exact. I'm pretty sure if i would have graphed every run from the old system it would have shown similar results.
Power is in the same range, this time I can do a few power runs and display them together to see the results. Just like above.
A lot more detail in these graphs, simply because I can graph every run almost instantly.
Stevetheboatguy
2:02 PM
Nw IL
A lot more detail in these graphs, simply because I can graph every run almost instantly.[/QUOTE]
Somebody give Joe a gold star please.
Steven
3:02 PM
Give him yours for fuggin up the quotes?
deye223
AIR FUEL SPARK VROOOOOM
5:02 AM
Australia
Black screen is way bettera
Red97
3:02 PM
MI
About 8,500 it gets all variable, ‘n stuff :rolleyes:. That the new norm?
That "variable" is what .04 ftlb looks like
The new system, and graphs allow me to do as above and lay the graphs on top of each other. Gives a very good look at the power.
The old system had a ton if filtering and averaging done to make nice smooth graphs. But not seeing the actual difference in the runs in such a fine detail.
Any thoughts on the 261 being less than advertised?
It is a 1st version 261c I believe those are rated a bit less than the v2.
That is in the same ballpark as the old system so I ran with it.
sixonetonoffun
2:02 PM
MN
That makes sense. It just made go huh? for a minute.
Red97
3:02 PM
MI
The little echo is pushing the low end of what the system can measure. A fly lands on the torque arm and can blow the HP 5% at that little power!
Actually seeing the filtering. It is unreal how much was going on with the old system.
I think a few little wobbles in the graphs should be expected.
As no engine it truly that smooth/linear in power delivery.
I plan to do 2-3 graphs just like the 2511 to show a range for each saw tested on the new system.
Waiting on the last email from tech support to make sure my settings are 110% before claiming any of these hp numbers to be true. Should be close, but not 110% sure yet.
3:02 PM
Do you want me to send a couple of mine back down that you already tested to compare results?
Nutball
2:02 PM
Mt. Juliet, TN
I think if there are any significant losses in the system, they really show on the 2511t. I'd think they could run around 2.0hp based on some comparisons Mitch did against a 2hp top handle: 201 or 355 I can't remember. Then again, I've never felt like a ported 2511t could out cut a 35cc top handle at least when it comes to torque in larger wood.
