Another chainsaw dyno...
Time's Standing Stihl
Below me...
10:19 PM
Central Iowa
Duane(Pa)
It's the chain...
10:19 PM
Centre County
I'd say yours is pretty accurate. Well before the breakdown.
Everything is calibrated with the same specs as the first time.
Everything I've tested again has been right on.
This is great news. Repeatable results give credibility to the numbers. As long as everything is in working order, the numbers it spits out are useful for comparisons. Like everyone has been saying... Thanks!!!
Red97
10:19 PM
MI
Thank you, I have a stock 50, and 90cc saw to go back to get my baselines. Long as they are the same it is good to go I figure.
Being calibrated with the same exact weight the numbers should be identical, which they were before/after the break.
Additionally, if you look in the Book of Excuses, appendix D page 9, you will see. “ Dyno torque arm strain gauge ffuk’t that day”. :risas3:
Well....
Everything was retested. And the new /corrected data was published on the saws that needed.
jk14
10:19 PM
Glenside Pa.
These runs were made over a month apart.
I'd say Scott has the 066 recipe dialed in pretty well...
They're some serious numbers there. Nice flat torque curve too. Is that the same saw in both graph's? Very close if it's two different saws.
