262xp R&D
PA Dan
FYD
8:31 PM
White Oak PA
So maybe a meteor works without a beer can?
I'll check when I get home. The one on the bench has the non decomp cylinder and 87 carb. I'm putting a Meteor in it. Get back to you a little later.
exSW
'Cause Thomas is a poopyhead
8:31 PM
United States
Are Meteors' A,B and AB pistons each a different run or just turned to that final diameter?
jmssaws
Banneded
7:31 PM
So if there is that much variable in diameter then five thou in height above the pin center isn't that out of line.
Tolerance for diameter will be in the 10's and 100's of thousands.
.005 is not in spec so they changed it for some reason, gasket or something
8:31 PM
Wow. Very small differences.
