- 3:15 AM
- Dec 30, 2015
- Brewster, NY
My 044 #1 acted very strange on me last week. It ran fine the first tank, but when I refilled it I also tried to adjust the idle a slight bit.
The saw ran fine for a minute or two, then when I let off the gas it started racing and I shut if off. It continued to diesel till I hit the chain break and did not use it any more.
I presumed it was a vac leak, torn boot or something, so I started taking it apart today, but do not see anything amiss with the boot.
So I quickly hooked up a vac tester (my first time using it). To save time, I sealed the exhaust port and intake boot with Gorilla duct tape. The exhaust seemed to seal well, but not the intake. So I put my finger over where it was leaking and I got the vac to hold from 10lbs to 9lbs for 40 seconds. I really think the only reason it declined is that the tape is still leaking a bit.
Does that rule out a vac leak as the problem, or do I need to seal that intake better?
I'm thinking if it is not a vac leak then it either must be the carb or a a timing jump.
Any thoughts? THANKS!!!
