- 7:00 PM
- Dec 29, 2015
- Ontario, Canada
First time I’ve seen double grub screws.
Hopefully it it can bleed vacuum off quick enough with both.
Well alrighty thenI've seen a bunch with two. One near the bottom, one at the end.
Is there a difference in a red lever model and a black lever model.... Be sides the obvious for all u wise guys out there. LOL
ConfirmedYes, red ones make Stihl fans go ooh and aah. Black ones, not so much.
I knew something like that was comingYes, red ones make Stihl fans go ooh and aah. Black ones, not so much.
Don’t believe soI think the earliest 044’s have a black lever then they switched to red then black again.
026 were just that way.Don’t believe so
Pretty sure I have before and after clearancing pictures. Thanks brutha. If not, I'll tag you in@Canadian farm boy
Are you gonna show the cylinder flange before and after clearancing?
I’ve got after pics if you need
