- 5:16 AM
- Dec 30, 2015
- Brewster, NY
Where's the good stuff?
This what your looking for???
Very nice work Mike.
Thank you for taking the time to share.
How did you handle the starter rope metal guide flare in the starter cover?
This model’s fuel line install has always given me issues.
It's the cylinder I want to see. Mikes work is top notch
I'm curious why your using grub screws as well as the umbrella tank vent. It's my understand that it's either one or the other, and only one grub screw when they are used.Putting the tank vent together. I used a short piece on tygon hose. The 2 grub screws get PUSHED into the hose. View attachment 124058 View attachment 124059 View attachment 124060 View attachment 124061
The grub screws are just to keep dirt and critters out of the vent. The old hose that I replaced had 2 grub screws in it so I put them both back in.I'm curious why your using grub screws as well as the umbrella tank vent. It's my understand that it's either one or the other, and only one grub screw when they are used.
I personally will not use grub screws. I lost a new 084 piston because the hose collapsed around the grub screw and caused the saw to go lean in a long cut. The umbrella is a true one way valve so no need for a grub screw at all.
It's more likely to clog up with the grub screws installed than without, and serve no purpose since you installed the umbrella. I'd just hate to see you hurt it.The grub screws are just to keep dirt and critters out of the vent. The old hose that I replaced had 2 grub screws in it so I put them both back in.
The parts were salvaged from the old vent. The tygon hose I've had for a long time. Think I may of got from eBay. No idea what the hose cost.My 10 mm 044 came with two grub screws, but the line has long since deteriorated. I have been replacing them with AM ones designed for the 029. Easier to install, cheap, and seem to work well.
Where did you get the parts Mike, and what did they cost?
The washers were used against the rivet heads when I was flaring the back side of the rivets.So what’s with those two big washers on the red cloth.
Btw,, This build is look awesome![]()
No other carb mods. The HD11 is an Arctic carb that originally came on the early 044 Arctics. It has slightly larger jetting then other 044 carbs. IMO it makes a very noticeable improvement in mid range and underload performance.Any other carb mods?
