Bigmac
- 5:50 AM
- Apr 19, 2018
- Oregon
Perfect, just wanted to clarify! Ya I don’t really feel it’s necessary to have two seals if everything is in good shape, I will get some of those seals and try them outYessir, just the one seal. The 6620 is a thick seal and it blocks the "weep" hole. I'm not really too worried about weep - that's from an era
when 16:1 was the standard mix. This saw will run 32:1 of the "good stuff."
The chrome on the other cylinder isn't bad - the engine previously had a moisture seize, but luckily Ross doped it up with PB Blaster
when he got it and it broke loose fairly easily. The old piston is junk but I think the cylinder can be saved.
That’s great on the cylinder!
