- 5:37 AM
- Dec 29, 2015
- Strong Island NY
Interested in hearing about which sealants you fellows use for your saw work.
I was using Dirko and really never has a problem. I just bought Loctite 518 and noticed it mentioned using an "activator" when using it. I haven't seen that mentioned anywhere here.
My reasoning for the 518 switch was the fact that it's supposed to only set up in the absence of air, so any excessive sealant that squeezes out into the area between the jug and case would be washed away instead of blocking airflow.
Which sealant do you guys use, why, and how do you use it?
