- 8:32 AM
- Dec 13, 2022
- Hamburg, NY
Next time use a zip tie. Usually but not always same material easier to use also. Plus Harbor Freight has a great/cheap plastic welding kit. HDPE needs HDPE to weld with. Anything that holds oil, gas, antifreeze, most garbage cans etc. is HDPE Member of SPE (Society of Plastics Engineers) class of '75This is good stuff. Thanks Paul. I tried to fix a leaking wedco gas jug the other day and ended up making it worse. I was using a woodburner tool , the kind that heats the tip and then you can draw or write on wood,, and I tried melting some weed trimmer string to fill the gap. Since I’m not a welder of any sort and know nothing about it, what would have been the best way to fix a puncture on a gas jug?
