- 10:01 AM
- Apr 28, 2016
- Croatia
Good chip clearance,
I have to upload a video of it to the Tube, it is a fast chain on my PS-550 in turkey oak.Good chip clearance,
That’s how chaps work: they stall out momentum. No rotation; no spark generated; motor stops.I have a question in relation to hard wood as in this thread.......
Last summer I was finishing splitting about 8 +(IIRC) cords and got tired of splitting crotches and knots to a stringy mis-shapen blob of wood.
Went through several saw rotations fer the heck of it and ended staying with three Poulan 5020's that I changed to .325 NK 18" bars......
The point of this being,.....several times noodling crotchy rounds down,....The chain would stop dead, at full song, and stall engine....like I hit a block of steel. VIOLENT!
Seriously concerning, knowing the weak crank at clutch end.....
Nothing found in the wood and no damage to chain. Just super hard, dense oak knots that could be polished to look like a chunk of bowling ball.
Have you ever experienced this?
Unless the chap material wound up in the clutch drum wouldn't the clutch just disengage and allow the saw to keep running?That’s how chaps work: they stall out momentum. No rotation; no spark generated; motor stops.
Higher torque saw, or less aggressive cutter profile, might have bounced, or kept going ?
Philbert
That is not how a centrifugal clutch works!Unless the chap material wound up in the clutch drum wouldn't the clutch just disengage and allow the saw to keep running?
I think my confusion came from my own reading comprehension or lack thereof.That is not how a centrifugal clutch works!
The engine can NOT keep turning max rpm if the clutch drum is stalled.
Or, it shouldn't be able to.
If it does Your clutch is fubared and You will overheat EVERYTHING on the engines clutch side in no time!
Hence the design of a chainsaws inertia brake, it stalls the drum and in doing so stalls the engine.
Well, on a centrifugal clutch quite often the sudden decrease in engine rpm when the clutch drum gets stalled will flood the engine and stall it out too.I think my confusion came from my own reading comprehension or lack thereof.
When it was stated stalling the motor and I was thinking killing the motor as in the motor died out like letting the clutch out too quickly in a manual transmission vehicle or not downshifting soon enough.
I use 27 for a lot of dirty stuff.There's some hate towards the Oregon stuff in here but thier 27X, 404 semi is a good compromise in dry hardwood. I did some testing with it late last year and it cuts about 8% slower than 46RS intially.
Half a tank a tank in and it's ahead by a lot. If you are testing cutting speed for this type of wood, don't judge it by how fast it cuts just after sharpening or out the box. Try timing it halfway through or after a tank of fuel and see how it holds up. It's no good being fast for 1 or 2 cuts when you have 6 hours of cutting ahead of you.
This is some old Dolmar branded 27X and how I file it. 85 degree side plate, 60 degrees on the top plate cutting angle and 30 over the top.I use 27 for a lot of dirty stuff.
Is it bone stock?Each time I take out my 660, I’m less and less impressed with the power, even with a 25” bar. I’m considering porting it. I know literally nothing about porting for more torque in hardwoods - I have lots of learning to do. But once it’s done I’ll report back with some more videos.
Thanks mate, yes it’s stock. How much would you advance the timing?Is it bone stock?
Try this
1.Open up the muffler even when it is a DP already
2. timing advance
3. some work on the carb
When it is still not enough, try porting
Try a base gasket delete. Porting almost always increases RPM, you just want grunt.Thanks mate, yes it’s stock. How much would you advance the timing?
