Tractorsaw1
- 12:14 AM
- Dec 29, 2015
- SHOW ME MO
Jim would you mind showing a picture of your handle bar mounting to cylinder?
What are the numbers in it now?I'd rather build another to sell. I'm porting this one to see what its potential is. I'm not going all crazy on it. The ports are smaller than what you'd normally see on a cylinder of that bore size so I'm just doing a little reshaping and I'll also put the ports where they need to be. The main thing is the tiny intake that's about 8-10° too high.
I don't know what I was thinking when I said that about the intake degree. It may even be a typo. It was more like about 3 degrees. All I have is a bunch of cylinders to match port locations. None of them are on saws to use a degree wheel so I just compare measurements. Before porting and after cutting the squish, this 272 was very close in numbers to a stock 372xpw. The only huge difference was the intake floor being higher.What are the numbers in it now?
I'm redoing that right now. I figured since I'm going to port it after test running that I'd get serious about that after I get the cylinder back off. The concept I was using left me just enough room to fit the Stihl upper av buffer with the little metal flange, but I don't like the range on it so I'm cutting fins to weld a little aluminum dowel so it is capable of using the entire stock spring in the correct location. The rubber Stihl av would have worked well but it would have looked like chit.Jim would you mind showing a picture of your handle bar mounting to cylinder?
I'm quite happy with this thing now. And that adhesive didn't budge.
The beginning numbers were whatever stock 272 numbers are. I still need to get the degree wheel set up to see what the exact numbers are. I raised the exhaust 6° and lowered the intake floor 4°. The roof of the intake was taken up to the bottom of the skirt at tdc. I took the transfers up just under one degree.It looks like great gains, do you have any pics of the port work, what were your beginning and ending numbers.
When a degree converts to a measurement you know how many degrees you went. Plus I wasn't using someone else's numbers or "recipe" to need one, I was using all three 372 cylinder versions for an idea of where to go and none of them are on saws.How are you measuring degrees without a wheel? How much room do you have before the ring drops into the intake?
I never said I was measuring degrees without a wheel. When a degree converts to a measurement you know how many degrees you went.
As far as the ring locating pins....it isn't running a 272 piston for that to matter. It's running an ms460 piston.
