Adirondackstihl
- 5:36 AM
- Dec 4, 2015
- Upstate NY
Use a collet or soft jaws........
If the measurements of the ID is the same after reaming them. I'm guessing it would be very close to the same from side to side.
If it was machined the same on each side...
If guys can make custom cranks
Weld, bore, grind on jugs
Modify, grind on pistons.
Then I'm sure a machined taper on the ID of a wrist pin would be just fine.
I get the whole using / buying the oem tapered one.
But like a lot of guys, there's a bunch of new aftermarket ones just sitting around.
If they could be lighten to match the OEM ones........why not?
Only when your busy
In these engines most of the time weight needs to be added to the crank in order to balance. So lightening the little end is better all around IMHOWhile lighter is better for RPM's, everything must be matched..
In the V8 or other 4 stroke's, when building a "Race Motor" and using lighter pistons and or rods, the crank balance needs to be matched.
While a balancer on the end of the crank helps with some vibration, the overall balance between the crank, rods, and pistons all need to be balanced.
Would it not be a good starting point in a saw to weigh a stock rod, piston, and pin, then weight the new lighter ones and remove enough from the crank so as to balance the entire unit?
I gots more time than money......Time is money.....
Good point except my Bud could not find either a water pump nor a bearing and seals to fit a Chevy 292 in line 6 for some reason .Would t it just have been easier to buy the right part?
Sorry bud, had to![]()
Okay. GFY. Felling much better now?Feeling lots of love right now![]()
There's a brain to pick.Talking to a friend that designs pistons every day for Mahle, he told me changing upper RPM limit from 12,500 to 13,000 is amazing the difference on bottom end and such even on a saw sized motor.
Sent from my SM-G920V using Tapatalk
Ooooo... In HS we could get rid of three or four grams in a few minutes. Easy peasy.
Forget safe. I took 14 off one. Braaaap brap...Think I can take 6g of mass off this meteor piston safely?
