stihl sawing
- 11:27 PM
- Feb 5, 2016
- Arkysaw
What's the name on those wrenches Brian?
King DickWhat's the name on those wrenches Brian?
red scotch bright, soaked in light oil or something like wd40.Is there any way of cleaning that old Starrett up without ruining it?
Thanks I will get some, I have the green scotchbrite, will that work.red scotch bright, soaked in light oil or something like wd40.
wipe clean then wipe it with tool oil, or any light oil, to keep it from rusting
is that a brown & sharp certificate in there? WTF!Yep, There's no date anywhere on it.
Dunno, let me take a pic of it.is that a brown & sharp certificate in there? WTF!
probably...as long as it aint sand paper!Thanks I will get some, I have the green scotchbrite, will that work.
Ok, i'll try it lightly and see if it works. I oiled it down a while back but was afraid to clean it. it's not real bad just a couple spots.probably...as long as it aint sand paper!
I think green is gonna be a little coarse for thatOk, i'll try it lightly and see if it works. I oiled it down a while back but was afraid to clean it. it's not real bad just a couple spots.
You are probably right, I use it for cleaning up rough stuff. I will get some fine stuff next time at the store.I think green is gonna be a little coarse for that
How old is that one?
I doubt it...its all hardened steel, all the markings are engraved so they aint going to come off...red is just finer so it clean it up better...I think green is gonna be a little coarse for that
*f-word if I know...I got it with a bunch of other stuff from an old machinist that was selling his stuff...he actually worked at starrett when he was younger, so it was probably supplied to him when he worked there...How old is that one?
You always did like it roughYou are probably right, I use it for cleaning up rough stuff. I will get some fine stuff next time at the store.
I bet that was just the certificate that came with a new micrometer , I don't think they calibrated that caliper...
Yeah, it was, you can see where it was stuck on the case in the one pic.I bet that was just the certificate that came with a new micrometer , I don't think they calibrated that caliper...
