What's on your bench?
Sty57
7:35 PM
Land of Cheese & Beer
Trouble visualizing. Hate to be a pain but do u have pics in action. Any vids ive seen is usually str8 on so u dont see behind the wheel only the front....
Sty57
7:35 PM
Awesome! Thanks Brian! Looks like ill be trying to take apart the old Milwaukee drill i have. Does the bolt thread into the back of the chuck?
Yuppers, I don't remember what the thread was on mine.
It was just a cheapo Chuck I picked up somewhere.
Just put the bolt in finger tight. Then you can loosen it and set it to zero easier.
JohnnyBlade
JUST GONNA SEND IT
7:35 PM
Momence,IL
Sweet ill bet i got everything in the shop to conquer this. I knew i held on to that old drill for reason:D
beaglebriar
The Peanut Gallery
8:35 PM
Warren Center, PA
Be prepared for a fight. The center bolt on the chuck is often held in with loctite. You might get lucky but they're usually stubborn.
Last couple I replaced on DeWalt drills, I cut off then put the heat to that bolt to get it to move.
JohnnyBlade
JUST GONNA SEND IT
7:35 PM
Momence,IL
Thanks for the heads up! Im sure it will be worst case senerio for me, just how it goes.LOL! Since i know this im gonna run out to the shop and PB the snot out of it! Then back to a serious game of Ker-Plunk with the boys:D
JohnnyBlade
JUST GONNA SEND IT
7:35 PM
Momence,IL
Tada! Would you believe when I looked in the bottom of the drill there was no bolt in it it was just threaded on it and I seized the opportunity and got it off with a set of channel locks with ease!!! We in bizness!!! Thanks fellas!!image.jpg
beaglebriar
The Peanut Gallery
8:35 PM
Warren Center, PA
Tada! Would you believe when I looked in the bottom of the drill there was no bolt in it it was just threaded on it and I seized the opportunity and got it off with a set of channel locks with ease!!! We in bizness!!! Thanks fellas!!View attachment 157621
You gotta be kidding me....
JohnnyBlade
JUST GONNA SEND IT
7:35 PM
Momence,IL
My DeWalt 1/2 hammer drill was the same way. Put the chuck in the vice, turned it to hammer in reverse, rattled the biotch right off.
FLMAO! Should of been a bolt in it but there wasn't. I had a 2nd one to check and it did have a bolt. I got lucky:D
Likesaws
8:35 PM
South west. Virginia
Note a way I have removed some chucks is to tighten Allen wrench into it and hit it with hammer breaks it lose no vice needed no fighting the channel locks. For old drills only can be hard on the gears.
Cut4fun
Redneck Chainsaw Repair
8:35 PM
Ohio
redline4
I'm huge in Japan
7:35 PM
Rosholt Wisconsin
What year? I dont recall my pistons looking like that on my 65 chevelle malibu when rebuilt in high school. But has been a long long time ago.
Quite a bit newer. 2016. Valve reliefs and dish is for clearance to the direct injector nozzle.
redline4
I'm huge in Japan
7:35 PM
Rosholt Wisconsin
Why dont they just make it a flat top?
Wayne, if you can figure out why automotive engineers do some of the things they do, you let me know.
I have been in this line of work since 1993 and have yet to figure most of it out.
The dish is needed to clear the injector. Most everything is interference, so with variable cam timing the cutouts are required so the valves dont meet the pistons during normal operation. Take all that away, it would be a flat top.
The new 5.3's are somewhat similar, but actually have a dome. Funky looking piston for sure.
