- 8:35 PM
- Jan 1, 2016
- Warren Center, PA
Ummmm...no spank you.Hell yes! Want this damn saw as a prize?!
Piece of shi.... I mean Stihl. Bugger has been a headache.
Can’t get right.
Name that movie.
you have my vote!Or maybe my first husky...
Got the 2159 about licked tonite. Just some final buffing and im calling it good. I have no base line to test off of cuz i toasted the piston the first time in a half of a tank cuz of a bad carb. No rhyme or reason for the way i ported either. No timing numbers wer takin. I feel i colored inside the lines OK, not perfect. My first one. BGD should be the only change. Not planning a timing advance unless strongly suggested. Just went off of pics and sugestions over the months. Just some good old grinding fun for science
Once i get it together ill post some videos and let the good people of OPE be the judge to whether i did good or u may see me chuck it in the woods! FLMAO!!! Im open to sugestions or ridicule until i seal her up. Thanks fellas! View attachment 157493View attachment 157494View attachment 157495View attachment 157496 View attachment 157497
Got the Malibu apart.
That chit wont buff out.
View attachment 157522 View attachment 157523
I like chainsaws so much better than cars..
Nah. Use the good chitMeh, a little JB weld and it’ll be like brand new
me too.Got the Malibu apart.
Bondo?Nah. Use the good chit
It is smaller than the intake. I thought the same thing. Ill measure the difference later. All i did was go about 1/4" each way from factory openings. The piston skirt wraps pretty fAr around so 1/4" is very conservative.What is the width of the exhaust? Looks a little small in comparison to the intake.
I have a wheel from when i built my car. My question is how does one fix the wheel to a saw without hitting saw case or parts? is there some adapter u guys use? Does it go on clutch side or flywheel side?I check timing using degree wheels I print off the internet. If your stock #s are good, you should be good, but sometimes intakes are way off. My most recent MS440 BB jug the intake was at 63 (w/o base gasket), I moved it to 78. Stuff like that can make a huge difference.
1/2 inch drill chuck is what a lot of guys use. Even 3/8 works, that's what I have.I have a wheel from when i built my car. My question is how does one fix the wheel to a saw without hitting saw case or parts? is there some adapter u guys use? Does it go on clutch side or flywheel side?
1/2” drill chuck and mount it on the pto side so you can use the FW to turn the crank.I have a wheel from when i built my car. My question is how does one fix the wheel to a saw without hitting saw case or parts? is there some adapter u guys use? Does it go on clutch side or flywheel side?
Trouble visualizing. Hate to be a pain but do u have pics in action. Any vids ive seen is usually str8 on so u dont see behind the wheel only the front....1/2” drill chuck and mount it on the pto side so you can use the FW to turn the crank.
