Redfin
Meh...
- 2:48 PM
- Dec 24, 2015
- Central Pa
Only the shadow knows.It probably got up in the intake boot John,I've shot one in there before and got lucky and found it.
That should buff out. Wtf got sucked in it
Glad u got her fixedOk guys I wanted to update everyone on my hybrid fuel issues. I think I have it all sorted out for now. Today I fired up the saw and began to tune it again.
The low side tuned great. Ended up 1 1/4 ish turns and the saw idles solid at 2800-2900rpms.
The high side also seems to be much better now. I ended up at 1 3/4 ish turns out. The high side rough tuned at 14200rpms. with a good 4 stroke.
The throttle response also seems a lot better now.
It appears that adjusting the metering lever up to be level with the top of the carb body did the trick.
I'll fine tune everything once I find some more wood.
Thanks again to everyone for the tips and suggestions.
Me too. I was beginning to stress a bit. I don't like when things aren't working the way they should, especially after you figure you did everything right. Oh well it seems fine now and I learned something. It's a win, win if you ask meGlad u got her fixed
Welp........I had to bush hog a few spots before they got outta hand. Damn cattle, they could care less if I'm injured.
Look what I found.
View attachment 15542 View attachment 15543
I think it might have been the other ring. Creamsicle with one ring ? Somthin fishy goin on here .[emoji12]That should buff out. Wtf got sucked in it
Yes it was the exhaust side.A little worn there on the right side. I think it is time. Was that the exhaust or intake side?
I will guess exhaust.
Wish I knew its history, got a new 42mm piston kit coming , its an oldie so no upgrade. Will do the seals to.That piston gave someone a lot of service!
Is that stock handlebar tubing?Put the finishing touch on her tonight. View attachment 15569
