What's on your bench?
Redfin
Meh...
5:39 PM
Central Pa
Got time to tear down my 661 to send the jug to Randy to machine for me. This is my first new saw that has only seen 32:1 K2 from the start. Im real happy with how it looked inside other than the standard 661 intake side scuff. Might be hard to see but the main is well covered in oil.image.jpegimage.jpegimage.jpeg
5:39 PM
Tore my echo 590 down the oil pump gear in the pump is stripped I've checked around does anyone know if you can buy just the gear separate or have to get the whole pump.
Carbine
5:39 PM
Ohio
I've got a Husky 50 I might do some grinding on when I find the time. Mostly trying to finish up a thinning gig I stumbled into, just waiting on the ground to firm up a little so I can get some logs moved out.
ny15
5:39 PM
Lima NY
That's a travesty!
Jon1212
Birch! Please.....
3:39 PM
Utah, unfortunately.....
Muh chain breaker, and spinner are on my bench. I made up a little platform for them, so that I can just C clamp the whole deal to my bench top when I want to make up some loops. Then remove when I need to go back to breaking.......er.......I mean fixing a saw.
I did learn this week that when you are miss shipped 3/4" punches instead of 3/8" you can modify/use a grinder on a 3/4" to make it work on 3/8" applications.
