- 1:52 PM
- Oct 21, 2016
- Kansas
I repaired a BR600 backpack blower for a mate and had a ball with it around the house
Walking around going "gohstbusters"
Was it like this?
Sure buddy send it over and I'll shine it up for you!Got this freebie also.....
Looks better on this side
oppps....
Luckily, I have a spare case
Anyone volunteer to do some cleaning work for me?
I have seen worse! [emoji24] [emoji23] [emoji15] [emoji13]
me tooI have seen worse! [emoji24] [emoji23] [emoji15] [emoji13]
Wow! Can't believe how some can get so bad!me too, I still remember one super dirty 346 NE I got for awhile ago, spruce tree work, food oil as chain oil! Could use xpg parts and fuel tank, rest was totally worn out lol
Maybe but don't discount the rot concept either. You do have the steel and such in the bearings and crank....so if corrosion was going to happen...which do YOU think is on the wrong side of the periodic table??View attachment 59860
Stihl KM85R power head in for a re-seal. Don't think this is a case of mag rot, porosity in the casting maybe? @afleetcommand
Oh yeah it can add up in a hurry on those wheelers. One rear CV joint I replaced over the summer was over 3 bills. Took about ten minutes to install. Customer wasn't happy about it but that's what you get for running them to failure.1990 Yamaha Big Bear, report was sometimes squeeks in reverse, and oil leak.
As you can see the one yoke is fubar, one ujoint cap is awol. Look like ujoint went then somebody kept riding, bent yoke, that shook front yoke enough as to loosen it, so now oil leaks past yoke splines, nut and washer, once I got it apart I could see where the entire rear axle housing had a big weld job, looks good from outside. Would like to know where the other cap is,,,the housing is closed....
You think saw parts are expensive,,,,
Used yoke $85Oh yeah it can add up in a hurry on those wheelers. One rear CV joint I replaced over the summer was over 3 bills. Took about ten minutes to install. Customer wasn't happy about it but that's what you get for running them to failure.
Maybe but don't discount the rot concept either. You do have the steel and such in the bearings and crank....so if corrosion was going to happen...which do YOU think is on the wrong side of the periodic table??Looks like a job for an OEM gasket augmented with a good goo gasket material...1184 (Bet you didn't see that coming..
I agree that if something were going to rot it would be the cases before the bearings or crank. The strange thing is I did not see any "white death" just this porosity, electrolysis maybe? Already back together and running, no gasket on the case halves, Hondabond HT only.
Joe
Not ALL on my bench.....but currently working on putting together our stihl spring order.....3 pallets of units
