What's on your bench?
Definitive Dave
Piss Rev Mafia Member
4:51 PM
Central Ohio
Dunno. But a 262 doesn't use a gasket. It uses a metal spacer that's shaped like a gasket.
now I am curious-er :)
is it flat or embossed with a ridge like the MS200T gasket?
In the Stihl literature (propaganda) they require replacing the embossed flat metal gasket any time the muffler is removed as the metal loses the spring tension that seals it when initially installed.
That was a huge pita on the MS200T in particular back before the aftermarket gaskets when the OEM was nearly $12 apiece.
I wa told the spacer for the 034/036 muffler conversion required two gaskets one for each side of the spacer?
always wondered how much it mattered to be airtight before the muffler considering how much we open up mufflers in the name of performance anyway
exSW
'Cause Thomas is a poopyhead
4:51 PM
United States
Had A few D282s they make your thumb numd holding the glow plugs.
Both mine start well as long as everything is up to snuff. The 560 is a little tired but crank speed makes all the difference. I don't like moving bales with the 706 cause it's a narrow front and it's a bit squirrelly even on a dry summers day.
PA Dan
FYD
4:51 PM
White Oak PA
OEM 262 muffler gasket/flange.
czar800
4:51 PM
Ellwood City
We had a 560,656 and a 706 the 560 had a turbo on it and it dynoed at 98hp it was a fun tractor! Most of the time there were only a few glow plugs working at a time on any given one.
Definitive Dave
4:51 PM
Central Ohio
it is crazy I cant find a spare inch of bench space anywhere as soon as I clean something off it is covered again, and I am not even doing any dang work
I am beginning to suspect that a few of you guys are sneaking around behind me sprinkling clutter-dust everywhere I go
again, completely up to code move along nothing to see here, mr inspector
I am 100% certain that I cleaned this table off and in the time it took me to pick up my phone, at least 5 items spontaneously appeared
