What's on your bench?
Brewz
2:16 AM
Hunter Valley - Australia
I know the model well.
I am glad I cracked it open for a full rebuild. The piston is worn and starting to transfer onto the cylinder.
Member
11:16 AM
A Husqvarna 562xp, nothing wrong with power head, just owners head, used cheap(Bad) bar oil (felt watery almost) and plum wore out the drivers on the chain with 3/4 tooth life left. Easy fix, change bar oil and new chain, bar is salvageable luckily. Hopefully it's a lesson learned.
Glock37
12:16 PM
Monroeville Pa
I need it for the oct 22 gtg here your getting the 395 in dec
11:16 AM
Surely you're not wasting your talents on ........that.
Those......there was a 590 outta the shot.....
I'll make sure you got it brother.
Thanks for the goodies. I traded the flashlight to the wife for a roll in the hay. :)
Glock37
12:16 PM
Monroeville Pa
She needed it to make sure she didnt break your legs ! Lol
12:16 PM
Well, I got that 461 running today, no smoke & runs good, I was pleased. Used my square file to reduce the size of that impulse nipple, then ran a 5/64 drill bit through it. Blocked off the crank to protect those bearings, then used the shop vac before flushing the case. At the last minute, I noticed the case was a bit deformed on the other side, the piston must have hit it (or a piece of it) when things went bad, so I smoothed that out too so it would not contact the new piston.
Also replaced the base gasket, plug, fuel filter, flushed the fuel tank, installed a dp cover and removed the limiters. I think he will like it a little better now.
So, I got 3 saws back on their feet for this guy (460, 660 & 461), and one to go (another 660). He has been keeping me busy! And I'm sure if the shop does not fix his 3rd 660, I will be seeing that soon also.
